Difference between 05 & 07?
I just bought my 1st MB and got a great deal because of 1 issue.... A cracked passenger headlight.
I was wondering if there is any difference in the fit of an 05 c230 headlight assembly and 07 c230http://cgi.ebay.com/ebaymotors/01-06...mZ330516127898? the car, 2007 c230 sport sedan , has stock xenon setup.
Its pricey at MB so I found this on ebay and wondered if it would fit? The price is so tempting and the look is sort of cool.
Now since I have stocck xenon, would my bulbs just slip right in there? anyone else with healdight mods on 07s?
You said your car has stock Xenon assmbly. Well that headlight isn't a stock Mercedes headlight and it's not even a stock Xenon headlight.
Unless I'm getting you wrong.
So your saying this wont even fit my car? damn. whats the diff if you dont mind me filling me in.... i thought w203 05 and w203 07 looked pretty similar
http://cgi.ebay.com/ebaymotors/DEPO-...item2eb4621c29
You can purchase this and try to swap out the parts and repair your original headlight. The reason I say this is you stock xenon is much better quality than this. But this is the best quality you'll find that's not factory.
If just the lens (clear cover) is cracked then you can take the lens off and swap it with the broken one.
If you put these aftermarket ones you will have to change both headlights because the light out put is going to be different. So I would say just buy this and use the parts that you need to fix the other one. And you'll have an extra headlight just incase the other side cracks lol
That seemed like a VERY safe assumption.. I guess none is safe.
Edit: Now I looked and WTF. No cars should have halo lights except BMWs, firstly. Secondly, why would you scrap factory Bi-X for el cheapo projectors over a cracked lens?! Buy a good used factory Bi-X.
i was looking at this too http://cgi.ebay.com/ebaymotors/01-07...Q5fAccessories
Im assuming buying a set that is meant for d2s bulbs would support my hid kit and bulbs as well....
VLILBENZ230: are you referring to the latest link i posted? they are for d2s bulbs are they not?
if im able to swap to aftermarket without fit issues, i;ll take that
Good Luck
