Unsilenced Kompressor
another user, but the thread might be on benzworld.
http://www.benzworld.org/forums/w203...ication-2.html
Im gonna tackle this soon....Ill let you know how it goes
Although I didn't really get to WOT because in one of those threads, someone says to use the T-bolt clamps, and right now I'm using regular hose clamps.
Someone also said that there's, or someone they know, had the tube come off with regular clamps. So I have been taking it a little easy.
The EGR nipple is just a 3/4" pipe connector. I drilled a hole in the main pipe, and had to bore it out so the EGR connector could thread in. I think a 1/2" might be better since the tube is a real tight fit over the nipple. I then sealed around it with high temp. RTV sealant.
The rubber end connector pieces are plumbing connectors I found at Home Depot. Their ID is a perfect fit over all the connections.
Like I said before thought, I really don't notice any difference at all. Even at WOT, in hard acceleration . Someone said his sounds like an F-16 spooling up, another said it was ear piercing in a tunnel... I certainly don't have anything close to that. Maybe it's the exhaust tube I used, I don't know, but I'm thinking it's not worth it.
If you end up doing this. Double clamp, and/or use T-Bolt clamps on the upper end of the pipe. Mine ended up coming loose. Got it fixed, but it did rub just a little on one of the pulley's.
I had to have a Local Performance Shop help me out with the welding, But the end result is Perfection IMO
I still have to take some Aluminum polish to the pipe and get rid of that discoloration for the visual appeal.
-- T-Clamps $35 shipped for 12 count (I plan on using the rest on an FMIC and I/C Pipe upgrade)
-- x4 4-Ply Black 2.5" Dia couplers $30 shipped
-- x1 3/4" Aluminum Vac. fitting $8
-- x1 17x1/2" X 2.5" Aluminum pipe with ends flared and 3/4" Vac. Fitting welded on $40
So just using the pieces meant for the mod, I'd say it cost about $80 total
Very Much well worth it to me.
I Promise to post more pics and a Video while I install and test the Mod. this weekend.
If I get around to it, when I replace my supercharger gasket I'll take a picture to show where it is.
