need your go defore the purchase ...
Wheels are Zolder from TSW ,18x8 ET 32 and 225/40/18 falken fk 452 , the rear is 18x19.5 ET 35 with 3'' lip depth 255/35/18 falken fk 452 .....
is that a GO
thanks
Fit is fine and I am lowered on Coilovers. You should be fine.
The hubcentric rings are made of aircraft aluminum and are not a problem. If you go with the TSWs, just tell the salesman that they need to have a center bore of 66.56 and if the wheel's center bore is not that (which it isn't) they better come with the rings. Also, the bolts for factory Benz wheel are r12 ball seat. Aftermarket wheels may use a tapered bolt specific to the aftermarket wheel. The key is that the bolts are A.) the correct length and B.) the seat of tha bolt matches the wheel.
My TSW's use a tapered goriila lock style wheel bolt.
Good luck on it.
do i put my springs eiback with a different pad from back to front to have a even look.. what is the stock # pad ? your sugestions ?may be im better with Tein S-Tech. drops about 2'' front and 1.2"back and stock pads
with one you prefer fist or second
for c240 sylver sedan v6
My car have 60 000 km,the back of my car looks lower than the front,i think its normal
Eiback drops 1'2'' front end back,do i put my eiback springs with a different # pad back to front to have a even look, your sugestions ?maybe i'm better with Tein S-Tech. drops about 2'' front and 1.2"back and stock pads
to have a even look
the tein-s actually sit higher than the sport sedan springs. if you're looking for all out performance, get the eibach or go for H&R.
Here's the pics i promised in the PM. TSW Crofts pre powdercoat.
https://mbworld.org/forums/c-class-w...03-wagons.html
my mom has a '99 E320 wagon 4matic, think it's right around 200k right now and still going strong!
.... is that cause a long therme problem ? sorry about that question but im a BIG 0 in mecanics
