Start issue on 2002 C320
I have a 2002 C320.
On Monday, after driving most of the day, I parked my car for about 30 minutes. When I tried to restart, the battery seemed to be engaging, but the engine wouldn't start. I tried again, and the engine started. The "check engine" light came on and stayed on for a while. I should also say, I was in the fuel zone where my reserve malfunction showed. I went to the gas station and filled up. The "check engine" light did not come on.
On Wednesday, the same thing happened, exactly...gas level very similar to Monday (reserve fuel level).
On Friday, the same thing happened. This time, I had half a tank of gas, but it still wouldn't start. I tried for 20 minutes and was unsuccessful. So, I disconnected the negative terminal of the battery and waited 30 minutes. The car started and ran for 2 hours on the highway, but as soon as I idled at a stop sign, it died. I disconnected the negative terminal again and waited 10 minutes. It started. No engine light appeared this time.
I'm at a loss as to what is wrong. I use 87 unleaded...might be the culprit on Monday & Wednesday?? I have 80K miles. No malfunctions appear.
I drive for a living and need to figure this out quickly...thanks for any and all input/ideas/advice.
Angie
Every now and again, usually if I don't start the car for a day, I will go to turn the car on and it will crank and the engine will start but it chugs a bit and dies after 1 or 2 seconds. After I try the second time, it works. What could this be? I don't have any check engine lights or anything on (besides SRS light but that's been on for a while).
It is held in place with one 7mm torx bolt.
Number 5 in diag.
Got the same car as your i.e. 2002 C320. Had simmilar problem i.e. late starting. Merc techs inspected and said its the fuel pump that weak. Changed the same but still no change. Again got inspection done and they found a faulty fuel injector. Changed that and thank God car starting has been fine since then.
Adding fuel injector cleaner to your fuel can also help if the injector clogging problem is not severe. Good luck.
