Will Oil Leak from Vacuum Pump Make It Hesitate at Low RPM?
2003 C230 Sport Coupe
Hey guys I'm new here and hoping you can steer me in the right direction.
I just bought a 2003 C230 Coupe and it runs poorly at low RPMs. It idles fine, but step on the gas and it hesitates 1 to 5 seconds before surging. It runs great on the highway, but stop at an intersection and it may not get going again without the hesitation.
Will a leaky vacuum pump cause this behavior?
The vacuum pump does have a considerable oil leak. I removed the pump, cleaned it up, put some RTV oil resistant sealant on the gasket and bolted it back on. It seemed to run better for about 10 minutes, then the symptoms returned. And when I got back home, I put my hand on the pump and came back with oil drenched fingers.
Any idea if the RTV sealant is just not working, or if the leak could be from somewhere else? It does not seem to be on the body of the pump (against firewall) but the oil is coming from next to the engine.
Someone else's thread mentioned that a leak may not be from the seals. Can anyone elaborate on this?
Thanks for any help you may be able to provide.
-Steve
-Steve
2005 c230 kompressor 2003 s500 94 wrangler
a member before said the pump will cause hestaition at idle
my pump is leaking also and i am having the same problem
pump is 200 and should take an hour to replace...its just 2 bolts and just remove the air hoses
