Changing my brake pads
Old Jun 3, 2011 | 11:26 PM
tingyangs6's Avatar
2006 c230
I'm tired of paying hundreds of dollars and then some at my local dealer on brake pads... In the past I had been changing my brake pads on honda and toyotas but ever since I got my C230, I always take it to the dealer. But it's too costly now, I was thinking about doing it myself. Any pointers out there and what will be my best friend (regarding to tools)? I'm also looking at quotes at private shops because people tell me not to do it myself because I will mess things up. Any advice is welcome.
Old Jun 4, 2011 | 04:21 AM
W203E35's Avatar
2006 C350 Sport 6MT
I purchase my brake pads from rmeuropean.com and I go for the Jurid brand because that's basically OEM but not in the benz packaging (same company that makes it for benz). Front is around 80 bucks and rear is around 60 bucks (price is rounded up). Then sensors if they are shot (if you get the brake wear message on the screen) are around 5 bucks each but Jurid supplies you with free sensors. If you don't have the brake wear message then the sensors are not shot and you can reuse them.
Take off wheel and on the caliper there are pins. Stick something in there to hammer the pin out. Once you get the pin out there is a metal clip that will fall off. Push the pistons back (I use the worn brake pads to push the piston back) but try not to push them all the way back. Just enough to be able to fit the new pads in.
Once you fit the new pads in put the clip back and slip the pins in place (might need to give it a gentle hammer to get them in nicely. Also take not that the clip is set incorrectly. If it touches the rotor it will grind and make noise. If everything is good and the pins are flush with the caliper you are done.
That's a brake pad change in a nutshell.
Edit:
The rear is similar. Also if you have to change the sensor too make sure you locate the pad with the hole in it. (the pad has a hole where the sensor slips into) The sensor is on the passenger side (front and rear). Recently I was in a hurry to change my pads and I put the pad with the hold on the left side. I couldn't fit the sensor so I just taped it to the caliper since I was too lazy to redo it.
Old Jun 4, 2011 | 10:32 AM
Silver C's Avatar
C240
Have a check on some DiY of those pads, if you are quite handy, you should be able to do it quite easily with proper tools. Good luck buddy!
Old Jun 4, 2011 | 11:32 AM
phister's Avatar
06 C230 SS 6spd
I use akebono pads and love them. OEM stopping but with hardly any brake dust. Do as karo said and it should be straight forward. Its about the same as changing the pads on an Lexus IS or any car that that uses a pin to lock the
pads. Also be sure to bleed your brakes in the proper order.
Old Jun 4, 2011 | 11:33 AM
carbonfiberwhor's Avatar
2006 C230, 2006 BMW M3, bye bye C55:(
Karo, where were you for my thread?
https://mbworld.org/forums/c-class-w...ttle-help.html
Some input would be great
Old Jun 4, 2011 | 03:37 PM
e1000's Avatar
a quarter mile at a time
You're going to kick yourself when you find out how easy it is to change the pads on a Sport Sedan.
Old Jun 4, 2011 | 11:33 PM
jogger's Avatar
02 S500
it is really easy using the instructions here. i purchased Jurid from RMeuropean and did not come with sensors.
Old Jun 5, 2011 | 01:36 AM
tingyangs6's Avatar
2006 c230
I heard that you have to change the rotors too when changing brake pads... Or are they just trying to hustle me?
Old Jun 5, 2011 | 02:38 AM
e1000's Avatar
They're just trying to hustle you. Just like any other rotor out there, measure for minimum thickness. When I had my car I replaced the rotors every other pad change.
Old Jun 6, 2011 | 01:24 AM
vdubpower's Avatar
i drive them all, fast and hard
is it still ok to turn rotors,
what is the criteria to do such a thing, for front or rear??
Old Jun 6, 2011 | 02:10 AM
e1000's Avatar
If there is no pulsation while braking, there's no need to turn or machine rotors. It's pretty rare that pulsation develops on the multi-piston sport brakes.
Old Jun 8, 2011 | 05:55 PM
It developed on mine
Old Jun 23, 2011 | 10:53 PM
Norwichdelta06's Avatar
2007 c230
proper order? And it is true you need to change your rotors each brake job you do?
Old Jun 24, 2011 | 06:10 AM
phister's Avatar
06 C230 SS 6spd
No you don't have to change the rotors every pad change.
Old Jun 24, 2011 | 09:20 AM
Grey Rabbit's Avatar
2005 Mercedes c230
You shouldn't need to bleed the breaks for a break pad change?? Am i right in saying this? The system is still closed unless you're taking off the cap.
Old Jun 24, 2011 | 08:11 PM
mleskovar's Avatar
'17 Jaguar XF
Bedding in new pads may be one of the most important steps for the whole process.....other than putting it together correctly Good high temp grease like ceramic based is also important.
Old Jun 25, 2011 | 08:03 PM
phil240's Avatar
07 c230
If your car has 4 piston calipers then it could be a bit more difficult to change but not likely e1000 is right it is like all rotors you have to measure thickness,but what he probably doesnt know is that european cars have softer metal in the rotors to help keep the noise down etc.. The other thing to remember is that if you put new pads on with out doing anything to the rotor then it will take a little longer for the full braking effectiveness to be had even with a proper bed in as the used rotors have grooves that are worn in from the old pad.
Im not saying you need to change or cut them,but most of the time rotors are cheap and now are more or less a throw away part. (unless you have the 4 pot system then they get pricey)
Old Jun 27, 2011 | 03:00 PM
tingyangs6's Avatar
2006 c230
Just got done changing my rotors and pads. It was pretty simple. It took me half the day because I didn't have a dead blower and c clamp. I encourage anybody who has a c class to do it by themselves. Spent $300 on parts and save $200 on labor. About the brake bleeding, I just open up the cap and pump the brakes a few times. Thanks members for advice!
Old Jun 27, 2011 | 03:01 PM
vdubpower's Avatar
whats a dead blower
Old Jun 27, 2011 | 07:47 PM
phil240's Avatar
07 c230
i think he meant dead blow hammer.
Old Jun 29, 2011 | 07:43 PM
BigAlC230K's Avatar
2005 Mercedes Benz C230K SS
Where did you end up buying your parts?
Price on pads and rotors please
BigAlC230K's Avatar
From where? Price on rotors and pads
Old Jun 29, 2011 | 08:05 PM
vdubpower's Avatar
how often are u guys changing rear rotors or pads??
Old Jun 29, 2011 | 08:47 PM
S4 John's Avatar
C230 Kompressor & B5 S4
That is not how you bleed brakes. If you are manually bleeding brakes you need to open the bleeder valve on the caliper and have someone push the pedal down. You have a hose connected to the bleeder valve and the fluid will empty into a container. Then, you close the bleeder valve before they release the pedal. You do this for all four corners. Starting with the longest brake lines which I beleive are the passenger rear, driver rear, passenger front and finally driver front. You need to monitor the brake fluid level and constantly fill it up.
Old Oct 15, 2011 | 01:11 PM
markinnaples's Avatar
W203; E60; '68 Camaro
Unhappy
Ugh. OK, I was changing my front pads when I removed the four bolts that hold the caliper to the bracket and brake fluid started leaking out until I put the lower bolt back and tightened it up when it stopped leaking.
Do I have a cracked caliper possibly?
The brake line is intact and doesn't appear to be leaking.
It's a 2005 C230K sedan, thanks.
