M271 breather hose replacement
Old Jun 22, 2011 | 04:28 PM
tiderfish's Avatar
C230 Kompressor Sport
Greetings, I need to replace the breather hose in my benz. At least that is what I think it is called. It is only a thin felt like fabric. The hose has torn at the inlet side on the passenger side. I have searched eBay, and this forum for replacements but can't find any. Any help is appreciated.
Ideally I would like to remove the bend and replace the hose assembly with the inlet on the driver's side. Thus have a straight pipe into the air cleaner box. Kinda like a ram air.
2005 C230k
Matt|ttaM
Attached Thumbnails M271 breather hose replacement-hose01.jpg   M271 breather hose replacement-hose2.jpg
Old Jun 22, 2011 | 08:09 PM
leeer73's Avatar
'05 c230, '09 c300, '03 Durango
Read post #22 for the driver side inlet:
https://mbworld.org/forums/c-class-w...r-removal.html
Take a look here for intakes:
https://mbworld.org/forums/c-class-w...1-intakes.html
Old Jun 22, 2011 | 08:58 PM
ambit's Avatar
09 CLK550
PN is A 271 090 03 82 you can find them for ~$60 online.
Old Jun 23, 2011 | 10:47 AM
tiderfish's Avatar
Thanks for the posts guys. I never understand why others can successfully use the search functions in vbulletin forums, and I have such terrible luck.
I also found this link.
http://www.mymercedesparts.com/partl...layCatalogid=0
(1) Air cleaner assy (2) Filter (3) Air inlet (4) Resonator (5) Air tube (6) Air tube Spring (7) Gasket
However the more I think about it, I would rather replace the Air Inlet tube with a RAM AIR type setup using the driver's side. I noticed on the resonator delete thread, it was breifly mentioned. However he had to cut and glue up some parts. I would much rather find a MB part that is made to couple to the Air cleaner assembly, and from there attach to the driver's side air intake port. Do they not make this for another car? Perhaps for the V6 or V8?
Thanks!
Matt|ttaM
Old Jun 23, 2011 | 11:06 AM
tiderfish's Avatar
I have been able to find the part for my car. But in the 1st link to the resonator delete and ram air thread, his part number is not found.
