05 c230| parking brake pedal issue
Old Jun 27, 2011 | 06:20 PM
///Icon's Avatar
C230K
Alright guys before anyone says anything I have searched the forums to see if I could resolve this issue but have not had any luck. The issue I am having is my parking brake pedal seems to get stuck on release at around 90% from full release. The remaining 10% I have to manually pull the pedal forward or else the brake light will continue to stay on. I notice that there is some play in the pedal for the last 10% where as there is some tension the remainder of the way. My brake pads are fairly new and the e-brake holds fine even on hills. My car is a manual trans. so I use the parking brake on a regular basis and Im thinking possibly a part has worn out. Any suggestions would be great. Thanks!
Old Jun 27, 2011 | 06:55 PM
eesjunin's Avatar
Nowhere ...Fast
E brake bracket under the rear bench seat...known to rust then either seize or break....lift up your seat, in the center unbolt a panel and you should see what's going on.
Old Jun 27, 2011 | 07:34 PM
///Icon's Avatar
C230K
I checked under the seat prior and everything is ok. Im thinking the issue is concentrated somewhere within the pedal mechanism.
Old Jun 27, 2011 | 09:18 PM
eesjunin's Avatar
Nowhere ...Fast
I believe that whole mechanism is a single part.i saw them on ebay fairly cheap:-)
Old Jun 27, 2011 | 09:36 PM
CHiKompressor's Avatar
2005 c230 S.S.
I had the same issue and just sprayed the hell out of the bracket under the seat with pb blaster. But i know some people have also tightened it to take some slack out of the line in order to get the extra 10% of the pedal to move up. I think the foot brake is what I hate most about this car
Old Jun 27, 2011 | 10:17 PM
Glyn M Ruck's Avatar
Super Moderator
Lubricate everything that moves or pivots.
Old Jun 27, 2011 | 11:14 PM
///Icon's Avatar
C230K
Thanks for the responces guys, I will check it out tom. and get everything lubricated and see it that works. Hopefully it does.. Fingers X
Old Jun 28, 2011 | 10:16 PM
Moreira_C230's Avatar
2006 C230 SS
I'm having the same exact problem. Some times the only way to fix it is to put the e-brake all the way down again and pull the handle a bit quicker. It happens only every now and again but it is annoying.
i'll give this a shot.
Old Aug 14, 2018 | 04:46 PM
Mikesbaron's Avatar
2005 C230
Did anyone figure out the fix?
Old Dec 23, 2018 | 02:33 AM
B Y's Avatar
B Y
C230 Sport
I know it's been like 4 months since last comment but I made an account just to write this because my friend just figured it out for my car today and it was very simple. Push down your e-brake, then pull it up as you pull the release handle. I know it's not a total fix but I tried it a bunch of times and it seems to work for me every time as long as I release e-brake this way.
Old Dec 1, 2019 | 01:42 PM
nlinesk8s's Avatar
C230 coupe
Fixed mine
I had the problem with the pedal not coming all the way up. I accessed the panel under the rear seat, and disconnected the cable from the pedal. I then sprayed the heck out of the pivot area and anything else in that area with penetrating oil, and worked the lever back and forth with a prybar til it loosened up. Reconnected the cable from the pedal and all now works very well. I think the parking brake doesn't get used a lot by most people, and over time just rusts.
