problem after install Bi-xenon for c230 coupe
Can anyone here help me pls? I just got a set of bixenon headlight for my 2002 c230 coupe part # 2038205761 and 2038204659 instead 2038205861. The guy told me they the same so i trust him. took my car to dealer to set it to present i gave them instruction i print here. Im not sure how they do but the recipe say coding set to not present. Take my car home spend 3 hours to remove front bumper and install the bi-xenon. Turn on the bi-xenon headlight the high beam is work but the low beam is just blink bink then off then blink then off. are they really just plug and play or i have to do any else.
C240
Xenon needs to be set to present if your car didn't come factory with xenons. Or else it wouldn't work.
But what's weird, bixenon hi/lo works with a flap. So if your highbeams work, then your lows should, too. Something tells me this may not be bix?
C240
Ah, then that's not bixenon. The "small circle" you're referring to uses a halogen. Simple fix to get the HID's (xenon bulbs) working- get xenon=present settings done. Otherwise, buy error cancelers.
2003 c240
agreed. Your description is vague. If your encountering flickering, it could be a couple of things going on. I'm not understanding the two circles you have. You should only have one projector and the smaller circle would be your turn signal, so the description doesnt make sense to me.
Yes the turn signal is working fine, but the one next to it, it just blink blink then off. And i got message check low beam light on. And yes i got the right part # 2038205761
it work now after bring it back to dealer to reprogram, They didnt do it last time. I dont know is it too late to upgrade my coupe it 9 years old already and only 50k miles.
mine is in the same boat age-wise... but i've been milking the mods every 3-6 months since warranty expired to refresh the "new" feeling. if you spread it out it makes it "last" longer in my opinion...
also, there are so many smaller cars in the market these days and i think our cars still look good... the only thing are the unexpected maintenance expenses, but it beats car payments. most of the time when ever i have to "fix" something.. i turn it into an upgrade and it makes keeping the car more enjoyable. unfortunately it turns into a money pit.
i say you should keep it and enjoy...
