C320 Engine Cranks but will not start...
Old Jul 9, 2011 | 11:51 AM
Russ8899's Avatar
C320 Sport Wagon
Mercedes C320 sport wagon: The starter cranks but the engine won't start. Plenty of gas and the battery is about a year old. Any ideas?
Old Jul 9, 2011 | 12:05 PM
Milkm4n's Avatar
2006 c230
crank position sensor do a search and you will find how to fix
Old Jul 9, 2011 | 12:46 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Fuel, Air, Spark... one of those 3 is missing.
Check fuel pressure via the port at the end of the fuel rail.
As suggested above, CKP is the usual suspect.
Old Jul 21, 2011 | 05:00 AM
muhammadph's Avatar
Mercedes C320 Model 2002
1. Get the fuel pump checked
2. Use fuel injector cleaner. My C320 has a late starting problem due to a faulty injector
Old Jul 21, 2011 | 09:00 AM
Glyn M Ruck's Avatar
Super Moderator
CPS - crankshaft position sensor. Do that first. It will never start if it does not know when it is at TDC.
Old Dec 2, 2013 | 07:16 PM
H.j's Avatar
H.j
c320 wagon
Hi, i have a 2002 c320. ( w203 ) i changed the crank sensor because i had a delay in start. Now that its changed i cant get it to turn over...... Some help please, would be appreciated THANKS!
