2003 C240
Old Jul 10, 2011 | 09:02 AM
dnunamacher's Avatar
96 c220, 97 s320 & 03 c240
2003 C240
is it normal to get a little smoke from the valve cover when you open the oil fill cap?
Old Jul 10, 2011 | 03:04 PM
phister's Avatar
06 C230 SS 6spd
are you doing this after the engine has been running for awhile?
Old Jul 10, 2011 | 05:04 PM
Glyn M Ruck's Avatar
Super Moderator
Yes!
Old Jul 11, 2011 | 05:46 PM
yes. but i also see sludge on the cap also. what do you think?
Old Jul 11, 2011 | 07:00 PM
Super Moderator
Is the sludge like mayonnaise or dark?
If like mayonnaise you might have a blown gasket & coolant leak.
If dark the car might not have been regularely serviced with the correect Benz approved 229.5 oils.
Change oil every 5000 miles until the sludge has cleared.
Old Jul 11, 2011 | 07:32 PM
contact148's Avatar
2003 c240 4matic wagon
if its cold outside and i do short trips i get the yellow sludge/goo on the oil cap
NEVER get it in the warmers months thru
Old Jul 11, 2011 | 10:00 PM
its dark i will make sure the oil is changed every 5k, thanks
Old Jul 12, 2011 | 08:02 AM
Super Moderator
Yes - in very cold conditions it is water from the combustion process getting past the rings. Made worse by short trips with the engine never getting hot enough to evapourate it all off.
In dyno testing over repeated 20Km's from a cold start I've got water in oil content up to 7%.
