HELP?! C240 Subwoofer and Amp Installation!
New to the forum. I have a 2004 C240. I'm getting two 12" Subs and an Amp tomorrow. I was wondering how to install all this instead of having to pay to get it installed.
Does my HU have a RCA Amp output?
There's a factory amp right? So how do I bypass that to use my amp or just put it parallel?
Any videos or DIYs on here that I could refer to?
I appreciate all the help. I've been stalking this forum for awhile just decided to join now
The Head Unit (HU) has no RCA or electric line level output. It has speaker output in standard trim, and optical output in premium trim. If you have Tele-Aid, a disc changer, satellite radio, or a phone interface the fiber optic loop called D2B in your model year is active.
System components for MY2005 and later are different with the optical system called MOST. They are not interchangeable.
The speaker output for your car is not the popular 4/8 ohm impedance, rather Bose made it different for their own engineering purposes. Makes it hard to change loudspeakers to another brand.
I am not sure why you would want two twelve inch Subs, because a single properly placed 10 inch will pack your kester into the next zip code.
If your new amp has a speaker level input, and the input is a high impedance opto-coupled type, you will be fine. Power is available on the rear SAM, and the sound level wires can be fished out of the door sill channels.
If you are not experienced with the Benz electrical system, you might want to find a shop that does work on them. A small wiring error can burn instantly through a tall pile of Benjamin's.
https://mbworld.org/forums/c-class-w...pictorial.html
-cars have a tendency to break down, let's all stop driving cars and just use trains instead. or are cars different and some are built better than others?
if you think those work well-why? infinity sucks on all aspects. (fact, not PO)
-using sound deadening stick on material will not stop flexing of that deck, just rattle.
don't ask how i came to the conclusion for all of my responses, for i will just reply by saying that i'm totally new to car audio and have no idea what the hell i'm talking about.
