M271: Help diagnosing problem (air/hose leak?)
Hey guys,
I noticed my car was sucking in a lot more air than usual. Basically, when I accelerate it sounds like there is a potential leak somewhere in a random hose. I did a quick look-over last night and didn't find any hoses detached. When I drove to work today, the "sucking" noise has gotten noticeable louder and I'm concerned.
My next guess is that something may be torn or leaking. I checked and I did get the engine vent hose campaign done on my car back in April 2008:
https://mbworld.org/forums/c-class-w...recall-10.html
But maybe its possible that it tore and is leaking again?
Otherwise, what else could be causing this / any particular hoses/lines I should be checking for tears/leaks first?
thanks in advance!
thanks in advance!
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Check aircleaner & all inlet hoses to the TB & MAF.
Check all vacuum pipes & breathers.
![](https://mbworld.org/forums/attachments/c-class-w203/214449d1310766687-m271-help-diagnosing-problem-air-hose-leak-m271-air-cleaner.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/159324d1245022894-rough-starts-mornings-m271-intake.gif)
![](https://mbworld.org/forums/attachments/c-class-w203/214453d1310766687-m271-help-diagnosing-problem-air-hose-leak-m271-kompressor.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/214450d1310766687-m271-help-diagnosing-problem-air-hose-leak-m271-egr-system.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/214451d1310766687-m271-help-diagnosing-problem-air-hose-leak-m271-vacuum-system.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/214452d1310766687-m271-help-diagnosing-problem-air-hose-leak-m271-vacuum-system-schematic..jpg)
