Sunroof malfunctioning? Use/try this...
Old Jul 27, 2011 | 02:50 AM
anonymousmoose's Avatar
Audi A4 Quattro 2013
Exclamation Sunroof malfunctioning? Use/try this...
So many of us have had the issue where the sunroof will not close unless we hold the button. The sunroof should fully close when we tap the button. What appears to happen is that the sunroof sensor indicates there is a object obstructing it and opens again half-way as a safety measure.
Sometimes a re-sync will work and other times (unless there is something stuck in there) the rills need a lube.
Well I had this happen to me about 3 months ago the dealer, I bought the car from, sprayed the rails of the sunroof with a solution and all was fine.
Last few days I noticed it happening again. So I thought I'd stock up on this stuff to do it myself. Bought the spray, sprayed the rails etc and hey-presto, works fine again.
So I just thought I'd share what spray I was using.
The dealer used the saBesto HHS 2000 spray, which I had a hard time finding in store. So I purchased an Australian product, Nulon Ezi-Glide.
Just thought I'd share if anyone else was looking at a spray to resolve this problem.
Happy for this to be made a sticky if it warrants it.
PS
If I bought the wrong spray, please let me know . I asked if the stuff was ok for the seals/rubber etc and the chap says it was designed with sunroofs in mind.
Attached Thumbnails Sunroof malfunctioning? Use/try this...-img_0867.jpg   Sunroof malfunctioning? Use/try this...-img_0891.jpg
Old Jul 27, 2011 | 01:04 PM
glocati's Avatar
2016 GLE 350
Good Tip. Thanks !
Old Jul 27, 2011 | 01:10 PM
Norwichdelta06's Avatar
2007 c230
I realize this was an issue also!! Because my sunroof will close fully or the safety device will kick in depending on weather so I knew it wasnt an electrical issue. I used high temp anti seize grease and havent had a problem since
Old Jul 27, 2011 | 04:51 PM
daiso''s Avatar
2005 c230 sport, k7 gsxr
yeah had this done at the dealer as well at a price of $40. I feel so ripped off. will try to look for that stuff
Old Jul 27, 2011 | 06:47 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My dealer reprogrammed the safety sensor with SDS under warranty. It mostly solved the issue, though it will kickback still on seldom occasions.
Old Jul 27, 2011 | 11:06 PM
Try the spray. I find that it start to do it occasionally, then it evolves into happening every time. After I spray it, its fine again.
Old Jul 27, 2011 | 11:14 PM
LILBENZ230's Avatar
Mine does the kickback thing like 2x a year maybe since the reprogramming. It's not a big deal - it was reprogrammed 3 years ago for the sensor to be less sensitive.
