New rear brakes, new problem!
Old Aug 8, 2011 | 03:25 PM
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
Put new rear pads and rotors on yesterday and after the initial test drive everthing seemed fine. Drove to work this morning and now there is a nasty grinding sound when the brakes are applied coming from the left rear. Almost sounds like metal on metal. When I release the brake pedal, you can hear a very faint intermitent scraping sound for the first few seconds, like the pistons are sticking a little, and then it goes away.
The pads are ceramic from Advance Auto along with their stock rotors. I know that I should have bucked up and gotten better parts but cash is short and was trying to save a few bucks.
Any ideas of what could be causing the issue? I plan on pulling everything apart tonight to see if there is something obvious.
Old Aug 8, 2011 | 04:45 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if they are the right parts you should have no problem. my guess is there is air in the brake system.
Old Aug 8, 2011 | 04:56 PM
eesjunin's Avatar
Nowhere ...Fast
i would say where you get them makes little difference ( many would argue)...but there is something not right if you install and get that sound...take it apart and see what might have happened...could the pin got lose and now the pad is stuck?
Old Aug 8, 2011 | 05:08 PM
zerocover's Avatar
2007 C280 4Matic
I would check to make sure the sequel reducing plate is still in place.
Old Aug 8, 2011 | 10:39 PM
SteveL1's Avatar
Almost too embarrased to say this but.........................I put one of the pads in backwards. Yep, I'm a moron. That metal to metal sound that I heard was after the backing plate had worn off and got caught between the rotor and the dust sheild.
The good news is that the Advance Auto Parts simply swapped out the old pads for a new set no charge. Awsome customer service! It actually pays to be honest some times and admit you are stupid.
All is back together and wrorking just fine now. Go ahead, I deserve it.
Old Aug 9, 2011 | 12:24 AM
samaritrey's Avatar
Super Moderator
THE C350
Well I hope no damage was done to the rotor but besides that I will keep my other thoughts to my self.
My mom taught me if you can't say anything nice don't say anything at all
Old Aug 9, 2011 | 02:55 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Steve, your the most honest man on this website .
Your experience reminds me of what my Chief Engineer said to me in his cabin when I signed on my first ship as a junior engineer." If you make a mistake & tell me about it I will kick your #rse but if you don't tell me I will #%#king sack you. I have abided by that advice all my life .
Good on ya mate.
Old Aug 9, 2011 | 08:20 AM
SteveL1's Avatar
Rotor had some slight scoring but nothing a little turning can't fix. Will take it to a local shop in a couple of days and get it cleaned up.
