Strange Noise: Timing Chain
my mechanic told me today that the cause of this strange noise is the OIL CATCH TANK! i still cant believe it, gonna replace it tomorrow and see if its truly this! we checked the timing chain area and everything seems pretty alright...
ok doesnt matter, i replaced the damn thing today and the ****IN NOISE IS STILL THERE! im DESPERATE!!!! it's a "rrrrrhhhh" noise !!!! i cant figure out what causes it nobody can!
#35
it doesnt sound clearly when i record it i can specify the area that the sound is comin from! its heard like something is loose and it trembles, rrrrrrrrr like a whistle. i can hear it from the right side of the engine and today i reconsider if its coming from the back area of the engine! the strange is that when i disconnect the s/c it isnt so loud!
#36
visited another mechanic today. he insisted that the noise comes from the timing chain case! when the s/c's belt if off the noise goes out about 80% so what has the timing chain area to do with the s/c ?
#37
FINALLY I MANAGED TO RECORD THE SOUND! HERE IT IS, UPLOADED ON FILESONIC HOPE IT HELPS TO GET TO THE POINT!
http://www.filesonic.com/file/184114...ange_Noise.wmv
or
http://www.megaupload.com/?d=8CDNBBFL
or
#38
I would put a new aux belt on first before doing anything else.
I put a new belt on & it quietened my noise immediately.
You are always going to have some cam chain/sprocket noise.
I cannot download your sound clip.
#39
http://www.megaupload.com/?d=8CDNBBFL heres a new link carsy
#41
Super Moderator
That sounds typical timing chain or cam adjuster to me.
Header/exhaust manifold leaks have a loud pfft, pfft, noise of gas escaping when the exhaust valve opens for that cylinder.
#42
My mechanic, when in trouble to find out the origin of mysterious noises, is using a doctor's stethoscope, with a plain steel stick at the end, instead of the usual little round diaphragm!!!
#44
Tappets ? .More than one .
Take your oil filler cap off to see whether the noise increases . Watch for oil splatter.
I would consider removing valve cover & checking wear & clearances.
#48
Super Moderator
Yes.
5 A 002 997 73 94 ROLLER CHAIN
Replaced_By: A 003 997 17 94 -
5 A 003 997 17 94 ROLLER CHAIN
WITH LOCK
OptionPart_With: A 002 997 99 94 001
5 A 002 997 79 94 ROLLER CHAIN
Replaced_By: A 002 997 99 94 -
5 A 002 997 99 94 ROLLER CHAIN
WITH LOCK
OptionPart_With: A 003 997 17 94 001
8 A 000 997 19 98 .CHAIN LOCK LINK
Replaced_By: A 000 997 22 98 -
8 A 000 997 22 98 .CHAIN LOCK LINK
TO 002 997 73 94, 003 997 17 94 001
8 A 000 997 18 98 .CHAIN LOCK LINK
Replaced_By: A 000 997 21 98 -
8 A 000 997 21 98 .CHAIN LOCK LINK
TO 002 997 79 94/99 94 001
11 A 111 050 09 16 SLIDING RAIL
Replaced_By: A 111 050 14 16 -
11 A 111 050 14 16 SLIDING RAIL
(CLAMPING RAIL) 001
14 A 111 052 02 83 .RUBBER LINING [009]
001
17 A 111 052 10 16 SLIDING RAIL
SLIDING RAIL TO CYLINDER CRANKCASE 001
20 A 111 052 01 74 PIN
Replaced_By: A 601 052 06 74 -
20 A 601 052 06 74 PIN
SLIDING RAIL TO CYLINDER HEAD 001
23 A 111 997 02 10 PIN
Replaced_By: A 111 997 04 10 -
23 A 111 997 04 10 PIN
SLIDING RAIL TO CYLINDER CRANKCASE 002
26 A 111 050 02 16 SLIDING RAIL
Replaced_By: A 111 050 11 16 -
26 A 111 050 11 16 SLIDING RAIL
29 N 914005 5006041 COMBINATION BOLT
Replaced_By: N 000933 3006147
+001 N 000137 7006204 -
29 N 000933 3006147 SCREW
SLIDING RAIL TO CYLINDER HEAD 002
32 A 111 050 04 11 CHAIN TIGHTENER
RANGE OF DELIVERY 001
---- A 111 050 02 11 CHAIN TIGHTENER
Replaced_By: A 111 050 03 11 -
---- A 111 050 03 11 .CHAIN TIGHTENER
HOUSING [417]
001
38 A 103 052 01 93 ..SPRING 001
41 N 007603 3027101 .SEAL RING
CHAIN TIGHTENER TO TIMING CASE COVER 001
44 A 601 991 00 01 .PIN 001
47 A 104 993 06 01 .SPRING
END PIECE TO CHAIN TIGHTENER 001
50 N 007603 3020100 .SEAL RING
53 A 104 050 01 66 END PIECE
CHAIN TIGHTENER 001
WITH LOCK
WITH LOCK
(CLAMPING RAIL) 001
001
HOUSING [417]
001
CHAIN TIGHTENER 001
