Headlight Question
If the ballast is bad, and I have to pull the bumper to replace, I was thinking that I might try to upgrade(?) to the bi-xenons listed on ebay: http://cgi.ebay.com/ebaymotors/01-07...item231305c609
The previous owner had installed aftermarket xenons, I think that they are Depos (Depo is written on the lens) but I can't find any model number. They are different from what is linked above in that my set has wires that run through the center of the black cap on the back of the housing.
My question, did my car originally come with HID? Is there any way to tell? I do know that after the new headlights were installed there are some female plugs behind the passenger side headlight that are empty. What does that mean?
Thanks guys, this whole headlight thing has been incredibly frustrating.
Early cars like yours could have had Xenons with frosted lenses & self leveling.
From 2003 onward Bi Xenons were available with clear lenses from Benz & self leveling.
Bix cars all came with headlight washers behind flaps like in my pic.
Sounds like your car has Depos same as link. They are OK but nowhere near as good as genuine. Genuine costs a lot more.
The easiest way to tell how your car came new is to look for the self leveling apparatus on RHS front sway & RHS rear axle.
Should you decide to fit genuine BiX I have the full WIS retrofit instruction for you.
I'm still curious about the empty female plugs behind the passenger side headlight. Is it possible that the aftermarket lights that were installed were not true "plug and play" types and that some sort of wiring harness was needed?
I've attached a photo of the bulb, it doesn't look damaged to me, anyone else have an opinion? Behind the bulb to the right is one of the empty female plugs I have mentioned.
I agree that factory bi-xenons would be the best and I appreciate your offer of instructions, but I don't think it's worth it to put more than 10% of the value of the car into new headlights.
One can't see from your pic if that Zenon lamp is OK. With time the gap in the lamp grows between the two electrodes where the arc is struck by the ballasts & the light becomes more blue to look at until it will no longer strike. So you could have a lazy ballast or a buggered lamp.
I recommend the genuine Philips Ultinon lamps. Samaritrey has posted their P/N's frequently.
try to
1. connect the "default" bulb with the working ballast, to see if bulb works.
2. connect the "default" ballast with the working bulb.
As your describe "the little "sphere" in the middle was a little grey", I think it might be the bulb does not work, as our experience, sphere is black, we could make sure it is bad.
For bulb replacement, you only cost less than $50 for new and brighter bulb, you also could install it by yourself, very simply.
If you have no Star available. Mark leveling arms where they mount front & rear. Detach them & with power on cycle them to their extremes in both directions & remount exactly where they were. This will usually reset the system.
Otherwise it's a Star & a lighterbox.
The only way to access the ballast is to remove the bumper and headlight assembly, correct? I don't have the time to be removing and installing the bumper just for troubleshooting.
My original thought was that the ballast was bad, but I'm not really sure. I also am not sure what type of ballast to buy.
I guess this is the problem with aftermarket parts.
I know it's hard to diagnose something without seeing it in person, does anyone need more info from me to help confirm the original set up?
https://mbworld.org/forums/attachmen...harness-1-.pdf
The sensors either fail - not common - or the system looses calibration over time much as the auto side mirrors, sunroofs, HVAC etc do.
Recalibration is then needed by cycling the sensors to their extremes so that the processor relearns the stops or resetting with a Star.
Next week, I will be installing the front sensor, follwed by the rear sensor.
As Glynn indicated, I will have to take the car to a dealer to zero out the lights with a star.
My estimate is about $500 for the complete install of the level system with all new OEM MB parts, an a lot of labor and scrapped hands.
I was all set to buy the Depo bi-xenon with the self leveling on ebay, but then I realized that they call for the original ballast. I don't think that the ballast is original on my car. I feel like I am left with two options;
1. Try to find an OEM ballast. I believe it is part numbers 1 307 329 088, but I'm having trouble finding an online source. Does anyone know of a reputable source for this part?
2. Try to use the bi-xenon without the self leveling. These come with their own ballast. Would these be plug-and-play?
