engine....
That only happens to me in the morning, when the engine is still cold, and after I start the car, I put it in drive or reverse right away. It shakes violently. But if I wait a little (like a minute) then it never happens. I also notice when the engine is not warmed up, it has a hard time shifting from 1st to 2nd for some reason.
I guess I don't let the rpm drop down all the way as if the engine is warm. I usually wait like a minute or so, so the rpm is still a bit high when I put it into gear.
As for waiting atleast a minute after starting, your RPM needle should drop...average time is about 30-40 seconds. I think it goes between 10 and 5 range after it drops.
The rought shifting is because it's still warming up and once its warmed up, it should be as smooth as silk.
Yup same here, not only it does that when i put on R, it does that everytime i switched on the Air con, or whenever i closed or opened the window into full extent, bad fuel pump??
