Coolant leak.. $3000+ job??
Did you check there? Though I'm pretty sure your mechanic did, but who knows...
http://www.ebay.ca/itm/OEM-Mercedes-...item23125f0623
http://www.ebay.ca/itm/Victor-Reinz-...item43a9be891a
http://www.autopartswarehouse.com/sk...3-1618459.html
I'll tell my mechanic that I will order the part myself, which will be $100 with shipping, and then just pay him the labour.
If it is around 10-12 hours as he says, at about $65, then I will be paying less than a grand for the labour too!
I think I am going to try the Rislone stuff from Canadian Tire that I posted a link earlier to first and see if it fixes the seal.
10 to 12 hours is more than enough time for the job.
So you suggest I get this..
http://www.rmeuropean.com/Part-Numbe..._7A6BBB7A.aspx
And what else from that web site? I was having trouble finding the rest of what you suggested
And this:
& 4 sets of these if you decide to do valves.
http://www.rmeuropean.com/Part-Numbe..._54299047.aspx
It always cheaper buying these things in kits than individually.
I'll bet the dealer wants the price of a whole kit just for the exhaust manifold/header gaskets.
Parts, even with the shop mark-up, are probably 200 bucks at the most. So..., that leaves 2800+ bucks for labor???
At reasonable shop rates that is, what, almost 40 hours???
In comparison, BMW straight six HG change is 1000-1500 bucks. Haven't needed it in my 330i because the cooling system has been kept up to date, but that's what the going rate seems to be.
My mechanics advise?
Keep driving it till it actually fails.
I 1st noticed it like 30K miles ago and it still runs fine.
I put a little coolant in every couple thousand miles, and just keeo going.
Yeah, it's an expensive job.
See here
http://www.kokes.net/slk/Engine_head...ead_remove.htm
I have contemplated doing it myself, but I'd like some help from someone who's done a
DOC before. And there's the "while you're in there stuff" like water pump, thermostat etc.
Maybe some hoses.
I have everything except a few parts.
But wtf? I runs fine so F' it.
Just to break it down, Thermostat is about 50, water pump around 250, gasket set around 150.
And then machine shop to lap the valves and plane the head, well, I'm not sure.
Maybe $400-500?
So maybe $1000 for the parts.
Then there's the approx 16 hours of labor required.
Ben Kokes said it took it a solid 8 hours to get the head off.
Putting stuff back together always takes longer.
Mine's been leaking for over 50K miles, and I just add a little coolant every once in a while.
Now at 207K miles, and not really worth bothering with the gasket alone since an entire engine with < 100K miles can be had for under a grand.
You'll see some white residue leaking down the side of the engine.
Good news, it just seems to push out the side and not into the engine.
It mostly seems to leak on heat up and cool down.
Yes, it's an expensive job, about 16 hours of labor + parts, +
the "while you're in there" stuff, like thermostat, new head bolts etc.
I'm just waiting for the 2002's to start showing up at the pick and pull, where ALL engines sell for $150.
They had a 2001 C320 recently so it won't be long!!!
We have recently gotten low coolant warnings, bought zerex and topped it up and the warning would eventually come back (within the month).
Pop the hood and there was less coolant and had to be topped up. The weird part is that there is no coolant on the ground on the driveway ever. So we just keep a bottle of Zerex in the trunk and top up whenever we need to.
Took it to a few different shops and they all said the same thing, something about a gasket that wuold cost $4000+ to replace.
Took it to our local/family mechanic and he raised the car and removed some sort of plastic housing from the engine and there was a bunch of coolant in it that just poured out. I guess there was no leaks on the ground because the plastic was holding it in. He also said it was a gasket issue and said he would help us out but it would be about $3000 (always helps us with prices) and looked the labour time up and it read about 10-12 hours.
Has anyone heard of this issue? I just called to confirm was he said, and he said it was clear to see the head gasket is leaking, and he will take another look to see if there is anything else.
Would a head gasket leak cause the coolant to be leaking gradually? There is no other issue with the car as far as its actual ride.
Also is a head gasket this time of price to fix?
(Canada)
Thank you
If I flush coolant periodically, I can prevent this? It's horrible. can't image this happening to my car ..
