Service Interval...
Old Oct 19, 2011 | 02:48 PM
cdaeng2's Avatar
c230 SS kompressor
Service Interval...
For past 2 oil changes(both A,B) when I reset the Service Light it only gives me 5000miles until next service instead 10,000 miles....
anyone know how to reset/change that?
thanks
Old Oct 19, 2011 | 03:04 PM
hcoronado's Avatar
2021 GLC300 4Matic
thanks
how many miles on your car?
Old Oct 19, 2011 | 03:30 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
What year is the car? Sounds to me like someone has reprogrammed it. The interval is 13000 miles most likely. Not sure why some people insist on wasting money/time/resources changing it more often. You can get someone with SDS to move the interval back up, or you can reset it at 5000 and change it when it comes up again.
Old Oct 19, 2011 | 04:29 PM
cdaeng2's Avatar
c230 SS kompressor
mine is 05 with 67k miles on it....
so i can't do anything myself on this one huh...
Old Oct 19, 2011 | 04:40 PM
LILBENZ230's Avatar
The proper interval is 13,000. Someone must have adjusted the interval down the STAR because they knew better than Mercedes who designed and engineered it (sarcasm).
You can't fix it without access to that computer.
Old Oct 19, 2011 | 05:47 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
i dont even have a service b interval...only service a
Old Oct 20, 2011 | 08:43 AM
LILBENZ230's Avatar
Once you reset after Service A it will show Service B.
Old Oct 27, 2011 | 06:22 PM
cdaeng2's Avatar
c230 SS kompressor
my c230 was at the dealership, and I mentioned it to my SA. He said he will look into it and reset it, but when they dropped the car off just now it couldn't be done, techs tried it dozen times and couldn't figure it out the drive said. What is going on? I need to talk to SA tomorrow but anyone have this issue? I remembering seeing a post saying computer calculates interval mileage depending on cold starts, and other factors... has anyone heard anything like this???
Old Oct 28, 2011 | 09:25 AM
LILBENZ230's Avatar
No the 2005 W203 just has a mileage counter.. it does not monitor oil quality based on any conditions. The techs couldn't do it probably because they are not as familiar with STAR as you'd think.. they often are confused by this stuff.
Old Oct 28, 2011 | 10:23 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
The techs couldn't reset it because their STAR systems don't have developer mode enabled. The only way to change it, is find someone with a Developer STAR system. Even then, you need to have an older version of DAS. Newer versions phased out that setting.
Old Oct 28, 2011 | 11:27 AM
cdaeng2's Avatar
c230 SS kompressor
hmmmm.... if dealership can't do it...not sure who to take to....
