C Class Tech Bulletins
You can try checking http://www.startekinfo.com . Tons of info there, it's just cost a few bucks.
• Factory Recall and Technical Service Bulletins (TSB)
• Information that addresses safety, reliability, performance and comfort related problems with your car
• Special warranty provisions and extensions
• Fixes for common problems and updated factory repair procedures
• Illustrated Diagnosis and Repair Procedures
• OEM Part Numbers
• Diagnostic Charts and Trouble Codes
• Component Locations and Diagrams
• Factory Maintenance Schedules
• And much more!
Just in case you haven't figured it out, alldata's website is alldata.com
https://mbworld.org/forums/showthrea...rvice+bulletin
Apparently the problem with the purge valve can be fixed by replacing a clip that's related to it.
If you do a search on purge valve, you'll get some Info. The problem is heard at idle.
Replacing the purge valve itself is fairly expensive if you had to pay for it (over $200).
