Turning Seems Delayed
Old Nov 1, 2011 | 10:53 PM
Class ++'s Avatar
C230 2006 Mercedes Benz
Hi everyone,
I have run into a problem with my car and I hope you guys can help me out.
I noticed a few days ago that I had to turn the steering wheel much more than usual to turn, in the past the car has been very responsive but now it feels as though there is almost a delay in the turning and it requires much steering wheel more turn to actually get the job done.
Does anyone know what could cause this? Could this be a problem with power steering?
I quick search of the forum didnt produce any relevant results.
Let me know if you have any questions, my car is a 2006 c230.
Thanks!
Old Nov 2, 2011 | 01:11 AM
W203E35's Avatar
2006 C350 Sport 6MT
Originally Posted by Class ++
Hi everyone,
Thanks!
You don't get any weird noise when you turn the steering wheel? Check the fluid level and turn the steering wheels all the way to one side then the other (3 times). Should bleed the system and hoping this may improve the steering responsiveness.
Old Nov 2, 2011 | 02:20 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Have you closely inspected your front tyres for wear? .
I wonder if your alignment is out? Hit anything lately?
Old Nov 2, 2011 | 02:52 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
this is happending to me at the moment....
i have a heavy steering wheel, lack of turning, clunking, and metal on metal noises when cold. my lower ball joints are shot
check your suspension components..
Old Nov 2, 2011 | 07:38 AM
Glyn M Ruck's Avatar
Super Moderator
And maintain suitable tyre pressure.
Old Nov 2, 2011 | 02:05 PM
Crna Mechka's Avatar
12 E350 4Matic Sport
Same here...wonder how much it will run me to replace all of these components at once...$2k-3k?
Old Nov 2, 2011 | 02:26 PM
yea if u go to the dealership 2-3k
but if u go to somewhere else it could be 1k depending what your replacing
Old Nov 2, 2011 | 02:54 PM
Probably all bushings/ball joints/anything else that goes with them for all four wheels.
Old Nov 2, 2011 | 05:32 PM
Class ++'s Avatar
Right on, ill check the fluid this weekend, i dont hear any whining however.
Also at hight speeds the car is much more responsive, low speeds i need to turn the wheel 360 degrees to make a 90 degree turn which i dont recall having to do in the past.
Ill keep you posted
Old Nov 5, 2011 | 10:50 AM
butthead713's Avatar
2014 Mercedes Benz E350
exactly. i just recently had this problem. steering was loose, hear funny sounds, and steering was heavy. so i took it to my mechanic (very trustable) and i had him replace all my bushings, both ball joints, and tire rods for 1K some parts we got lucky and found used. Its easier to find parts in big cities and in Houston ummmm almost every one has a mercedes!
