Car stalling then won't restart. HELP
My c class 240 stalls at red lights and stop signs occasionally and then won't restart for about 20 minutes. It turns over but won't fire up. After waiting awhile, it starts fine with no problems. Could it be a bad fuel pump? Battery? Crank position sensor? Camshaft position sensor? spark plugs? HELP PLEASE!!!!
very likely Crankshaft position sensor. Before replacing any part, first check and see if there are any diagnostic codes set.
Super Moderator
+1 - You can try pouring cold water on the CPS. It gets very hot mounted at the rear of the engine. If she then fires up you know for sure you need a new one. Read stored codes as pcy suggests.
2009 Porsche 911 Carrera S
I had this same problem two weeks ago and for what it's worth... it was the Crank Position Sensor.
No complaints on my part! Since my car is a '04 C240, it's about time stuff starts to break or deteriorate.
Super Moderator
It is DIY but a real fiddle due to poor access down the rear of the engine. You have to work blind to remove a torx bolt. Need the correct tools.
BTW - The cold water trick is what Mercedes roadside assistance have been trained to do.
Super Moderator
Never known it required. Haynes manuals are not the best on these cars. Full of mistakes. Please don't believe their torque settings.
