First time Oil Analysis
The calcium is too low to be the 0w40 formulation.
I have ran repeated reports of 0w40 and the 5w40.
This report is the 5w40 Formula M (for gas cars).
It is a 100 percent perfect and acceptable oil to use. It just isn't the 0w40 oil.
Calcium will go down some during the oil life, but not by 1000 ppm in just 5000 miles. You will see my calcium between the 138 mile check and the 4000+ mile checking didn't change at all essentially on my report below.
I have a virgin analysis of this oil for you attached.
You can see how low the Calcium and other things are in it compared to the 5w40 Formula M (non-ESP) in the right two columns of my report above and the original posters' report. This oil below is for diesel only.
I know it's very confusing that there is also a Formula M for gas cars.
Look at the low TBN (5.5) of this oil, again just for diesel. Wouldn't last long enough in the gas car.
The original post and the older two analysis of my report above is this gas product:
http://www.mobil.com/USA-English/Lub...a_M_5W-40.aspx
They don't even put it on the regular Mobil site. It's only at the Mercedes dealers. It's very confusing. It was designed just to meet Mercedes spec. I think many dealers started using this (the gas version Formula M 5w40) around 07 or 08, previously they did use 0w40, so many of them might still call it that.
That does not seem to be 0w40. It's not bad that it isn't, it just isn't. I don't know if you mean the report from the oil change? Blackstone simply puts the oil down as whatever you list it when sent in.
Go pull up any other Mobil 1 0w40 at the oil guy site, you can see. None will have your Calcium number.
The only way around it I can see if you put the bottles in yourself, and they were some very old formula that I have never seen before.
However, your numbers match up perfect to Mobil 1 Formula M 5w40, which is what most dealers have been using the past few years. Penske dealers have now switched to the Pennzoil 5w40 product.
You may be right! Pretty observant!
I thank you again because your analysis is one more confirmation that hopefully we'll all have pretty good luck from these engines (still knock on wood here).
I don't know how smart it is for us to spend the money on analysis, but it is interesting, and perhaps it does prevent us from foolishly thinking we need more frequent oil changes, which saves some money and the environment.
LILBENZ230 figured out the optimum oil change interval (at least for his car) was about 12,000 miles. It is nice to keep that for reference...
If we want to be picky - The viscosity of the 5W-40 has sheared out of grade. It should be >12,5 cSt at 100 deg C to fully meet the 40 grade spec. The extra Calcium in Mobil 1 0W-40 Eurograde gives greater overbase & thus better TBN & TBN retention. It will also provide better protection of the valvetrain & better piston scuffing protection. The 0W-40 is the better product of the two. The difference between meeting & exceeding specs.
Remember that TBN is less important in Gasoline engines than in Diesel engines. Diesel fuel contains more sulphur, the byproducts of which requiring to be neutralised. The real benefit of extra Calcium in the M1 0W-40 is the better wear performance.
While I "have you on the line", you might have some insight into the cam sprocket situation. I understand MB will take care of me should it fail, but would they take my Blackstone oil analysis as evidence that it was GOING to fail and then fix it for me? Are they going to want to verify my analysis with one of their own? Or are they going to make me wait for something bad to happen.
Johnand said that my VIN was in the "bad" range but of course, that is only an indication that it is much more likely to bite me than that it will bite me. I would feel a lot more comfortable with a machined steel sprocket, though!
Was this an issue only with the 2.5 liter M272? What about the 3.0 liter and 3.5 liter from the same years?
It seems with any good we purchase, there ends up being something to watch out for!
https://mbworld.org/forums/c-class-w...time-help.html
There is no reason whatsoever why you should not get another 10 years out of your car.
If you Google you will probably find there is a class action going.
In a nutshell some M272 engines have balancer (Lanchester) shaft chain drive sintered sprockets that were supposedly not hardened correctly. Thus the chain & sprockets wear out on the balancer shaft drive. Benz will repair even outside warranty. Sintered sprockets have been replaced with machined steel ones.
I did a search and found this: https://mbworld.org/forums/c-class-w...ml#post4569933. Maybe this will help.
