coolant flush or no?
Old Nov 17, 2011 | 02:27 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
i still havent changed my thermostat yet
but i was wondering do i have to flush the coolant when changing the stat
i heard on here u can take the coolant cap off and let the engine bleed the air out inself after replacing the stat
thanks
my battery is almost 7 years old...haha but im worried who ever replaces it might fry the sams..or more damage
cant afford that non sense right now
Old Nov 17, 2011 | 05:21 AM
Glyn M Ruck's Avatar
Super Moderator
No need to flush coolant at Tstat change. Your car should have the silica gel sachet in the surge tank to top up silicates. If so coolant can go 15 years.
Only change if it is discoloured.
Old Nov 17, 2011 | 05:42 AM
thanks glen
any idea on how to replace the battery without causing the sams or anything else from frying?
Old Nov 17, 2011 | 03:01 PM
phister's Avatar
06 C230 SS 6spd
Change the battery per user manual... Remove ground first then the postive and on reinstall do postive then ground and you'll be ok. Then just resync all windows.
Old Nov 17, 2011 | 04:48 PM
AdidasC230's Avatar
Saab 900 SE
What he said, thats how MB techs do it.
Also PS your car looks awesome
Also MB dealers are with GLYN they dont reccomend it be changed unless it has turned color or is 15 years or older.
Old Nov 17, 2011 | 08:18 PM
Super Moderator
Just buy yourself some concentrate. Dilute 50% with de-ionised water & top up loss.
