Oil burning
Old Nov 20, 2011 | 07:56 AM
springdriver1's Avatar
2006 ML350 back from dealer after 4 weeks,now back for oil consumption test!,2003 C230 Sport
Oil burning
Hello guys any of you c230k owners with more than 170xxx on motor having any issue with the burning oil. It called for an quart about 1800 miles ago now the light is on again! Do you guys think just the age of motor or an problem thanks for any feedback!
Old Nov 20, 2011 | 10:16 AM
LightDragon's Avatar
w203 M111 E20 ML EVO
IN *NO* WAY THE AGE CAN BE THE CAUSE OF THIS! I have about 350.000kms on my benz and it rolls as the 1st day I got it. do u see any oil leak stamps on the floor or the road when the car is parked for a while ?
Old Nov 20, 2011 | 11:57 AM
No I looked around not an drop on the ground. Then the strange thing is that I got the low oil message last nite on the highway. Then about an hour ago check oil the car say that the level is OK. At this point I let it run for about 10min the low oil light never came on!
Old Nov 20, 2011 | 12:30 PM
hmm ok, do u notice any leakage on your engine ? or is it clean ?
Old Nov 20, 2011 | 12:53 PM
Glyn M Ruck's Avatar
Super Moderator
Some oil consumption is not to be worried about. However, have a good look for leaks. A minor leak can distort consumption drastically. Karo saw no obvious leaks on his car but it was dripping down the back of the engine (C350) & consumption was bad - now fixed.
Do another thing for us & report. Run the car down a long hill against compression (foot off the throttle). At the bottom mash the throttle to the floor while keeping an eye on the rearview mirror. Does the car blow a cloud of blue smoke & then clear? If so you need new valve stem seals. A simple dry & wet compression test will put your mind at rest on rings.
Old Nov 20, 2011 | 12:55 PM
I'd also advise him to measure the oil manually as it can be a faulty sensor reporting...
Old Nov 20, 2011 | 12:57 PM
My car asks for even 2.0L of oil more at each change but after a while it's just ok. that's why u have to make sure it's indeed burning oil
Old Nov 20, 2011 | 03:17 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
first if u drive alot of miles on highway ur gunna use oil
your cam magnets can be leaking, air pump can be leaking, your main seals can be leaking....and plenty more
i only drive highway and my car reads 4 quarts instead of 6....but i havent changed the oil for 9k miles
Old Nov 20, 2011 | 05:24 PM
In any case, *IF*oil burning occurs, try pouring a can of B-2 Oil Treatment in ur engine....
Old Nov 20, 2011 | 07:59 PM
Thanks alot guys I checked around the cam magnets an it was alot of dirt there they may be leaking. How much is this fix? I will try the hill test in the morning.
Old Nov 20, 2011 | 10:37 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
In my experience valve stem seal oil useage is shown by immediate smoke from exhaust at startup., particularly after say an hour at rest.At shut down the oil rings pass the worn valve stem seals into the combustion chamber.
Smoke at the bottom of a hill after de-accelleration in my view is a result of worn piston & oil rings. ie high vacuum in inlet manifold & above the piston bringing oil & oil vapour to the top of the piston which is burnt when combustion begins once again upon accelleration..
When the engine is hot it may be possible to disconnect the engine crank case breathing pipe ( which enters the air intake system) & to view how much , if any, piston bypass you have.
It sounds as if you will have to ascertain the correct sump level first up.
Good luck.
JC
Old Nov 21, 2011 | 09:25 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Park the car for a while on a completely level surface.. use dyno mode to see exactly how much oil is in the sump. Adjust to its maximum of 5.5L and then monitor consumption.
Right now you don't know exactly what point the car is asking for more.
Old Nov 21, 2011 | 09:30 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
It's a 2003; I'd go off the dipstick instead.
Old Nov 21, 2011 | 09:52 AM
LILBENZ230's Avatar
I didn't realize the M271 cars ever had dipsticks.. my bad.
Old Nov 21, 2011 | 09:57 AM
tommy's Avatar
I believe they do, or that you can still get the dealer tool to manually read the oil level if it doesn't come with a true dipstick. I'm sure someone will correct me if I'm wrong.
Old Nov 21, 2011 | 10:02 AM
LILBENZ230's Avatar
Using dyno mode for a specific reading is still the most accurate. A dipstick tells you Min, Max, normal.. dyno mode tells you 5.4L.
Old Nov 21, 2011 | 10:16 AM
tommy's Avatar
True, but I think that lightdragon has a good point about the sensor possibly being faulty too. A dipstick would be at least a good backup against that possibility.
Old Nov 21, 2011 | 02:35 PM
Carsy's Avatar
+1
Old Nov 21, 2011 | 05:16 PM
Super Moderator
Good luck.
JC
If you have ever owned an Alfa - I've owned 7 of them in my life - You would recognise that high vacuum in the inlet manifold causes smoking after long deceleration & then accelerating due to oil coming down the valve guides. Alfa runs no guide seals & depends on valve stem to guide clearance for oil control. As a result they all use oil by design. The old Jag, 2.8, 3.4, 3.8, 4.2 family of engines are also inclined to smoke due to oil coming down the guides in these conditions. See my garage. Worn rings will usually show a certain amount of continuous smoking.
Both engines designs are twin OHC like the M271.
Anyway - A wet & dry compression test will give an indication of ring wear/damage.
Old Nov 21, 2011 | 10:58 PM
Carsy's Avatar
Glyn,
No, I have not been fortunate enough to own an Alpha !!
My 1977 Chrysler Hemi Utility used rubber valve stem seals & they needed replacement often to prevent a cloud of smoke at start up.
My 1962 Holden Utility OHV & 1951 Wolseley 680 over head cam always issued smoke at the bottom of the hill after accelerating . Both had poor compression & worn rings.
My vehicles were probably a lot more worn than yours.!
Our experiences seem to differ but I am cool !! If the truth were know we are both correct .
Old Nov 22, 2011 | 07:07 AM
Super Moderator
Agreed! On the M271 it's usually just valve stem seals if the engine has been maintained & not abused.
Old Nov 23, 2011 | 01:50 AM
Thanks alot guys been working so I haven't had time to try anything. The still haven't came back on so I will try dyno mode to see what the level is an go fr there.
Old Jul 2, 2013 | 06:18 PM
wewong's Avatar
18 C300 Wagon
Trying to revive an old thread. My MY2005 C230K requires 1L oil every 5,000 km. The engine has close to 200,000km on it and I do mostly highway driving. No oil spot under the parking spot, don't believe there's any leak around the cam sensors.
One thing I noticed when I changed my spark plugs a few weeks ago was there was oil around the hex portion of the spark plugs in cylinder #1 & 2 (i.e. puddle of oil sitting in the bottom of the well where the spark plug is screwed onto the head, outside of the combustion chamber). The electrodes on all the plugs are dry and have the normal brownish color. The oil seems to be clean, so I suspect it came from missing the oil filler area when filling up.
Where else should I be checking?
Old Jul 3, 2013 | 12:07 AM
Super Moderator
You have a leaking cam box gasket or O rings. Otherwise consumption is OK for mileage.
