dumb CEL query
Old Nov 26, 2011 | 11:51 PM
ulmapache's Avatar
'05 c-230k,(scrapped at 97000 miles, MB unable to effect mechanical repairs) '97 c-230
dumb CEL query
Sorry if this is a repeat of an existing thread/post, searched, nothing came up.... Ok, CEL on, have code p2226 and p2228, meaning barometric pressure sensor issues. My query...is the sensor integral with the MAP sensor, or is it a seperate unit, and if so, where is it located. Vehicle is 2005 c-230 ko0mpressor. Thx....
Old Nov 27, 2011 | 12:04 AM
B16RacerN2NR's Avatar
06 Pontiac Vibe, 01 Dodge Ram, 01 Honda CBR600
It is integral with the MAF (Mass Air Flow) Sensor
Moderated - not true
Old Nov 27, 2011 | 02:35 AM
ulmapache's Avatar
MAF is new....no other codes present. Any idea as to what is going on?
Old Nov 27, 2011 | 08:09 AM
Glyn M Ruck's Avatar
Super Moderator
Did you cancel the codes? If not it could take over 100 miles to auto cancel after fitting a new MAF & sometimes not at all.
Old Nov 27, 2011 | 11:35 AM
I agree with Glyn...
Also, I NEVER replace a MAF without also changing the air filter(s). Did you change yours at the same time?
This doesn't happen all the time but a handful of times I have run into a problem where a new MAF won't/can't self adapt because of dirty air filters. Even only "slightly" dirty as well.
Old Nov 27, 2011 | 11:55 AM
ulmapache's Avatar
New air filter/fuel filter...MAF, sparkies, ignition coil assys, .... This is getting to be tiresome....and I thought my next car was going to be an E-63....might be a '40 Ford w/ a flathead....
Old Nov 27, 2011 | 04:03 PM
Super Moderator
Old Nov 27, 2011 | 05:06 PM
ulmapache's Avatar
Yes, twice....
Old Nov 27, 2011 | 05:08 PM
ulmapache's Avatar
Am going to replace new MAF with old one and see what codes come up....back in an hr
Old Nov 27, 2011 | 05:20 PM
Super Moderator
Is the new MAF a genuine part? VW/Audi MAF's look identical but won't work on a Merc.
Old Nov 27, 2011 | 06:03 PM
ulmapache's Avatar
This one is the original, genuine part, VDO Siemens....swapped out new one for old, original one, took test drive...here's the freezeframe.
Old, original MAF/"New" MAF
ABSLT TPS 18% / 13.7%
RPM 2058 / 1072
Calc Load 15.6/11.3%
MAP 38(KPA)/29(KPA)
Coolant 96 F (not warmed up completely)/129 F
ST FTRM1 0.0%/0.0%
LT FTRM1 0.0%/0.0%
33mph
Fuel sys1 open (does this mean fuel cap open/defective?)/Open
Don't know if this is relevant, but looking at the MAF plug noticed it has 5 female recepticles, only 4 have metal contacts, MAF has 5 male pins. Does this mean anything? Here's photos...Thx
Old Nov 27, 2011 | 07:24 PM
ulmapache's Avatar
Thumbs up
BTW...nice view....
Old Nov 30, 2011 | 02:09 PM
ulmapache's Avatar
[QUOTE=ulmapache;4935005]This one is the original, genuine part, VDO Siemens....swapped out new one for old, original one, took test drive...here's the freezeframe.
RPM 2058 / 1072
MAP 38(KPA#/29#KPA#
Coolant 96 F #not warmed up completely#/129 F
ST FTRM1 0.0%/0.0%
LT FTRM1 0.0%/0.0%
33mph
Fuel sys1 open #does this mean fuel cap open/defective?)/Open
DTC code p2228
New air/fuel filter, spark plugs, coil ignition units, no vacuum leaks
Any ideas on which sensor to go after?
Old Nov 30, 2011 | 05:26 PM
Super Moderator
P2228 = Barometric Pressure Circuit Low - you know this
The freeze frame tells us nothing. Just gives
Throttle position
RPM
Load
Manifold pressure, coolant temp, speed etc.
"Fuel sys1 open" means the engine is not fully warmed up & the injection system is still running "open loop" i.e with enriched mixture & ignoring O2 sensor input.
You might have to get this car onto a Star to find why the aneroid "barometric sensing" is haywire.
I do not know the M271 as well as the bigger engines. The 4 cyl models use a different injection system. I just want to check the post above that the aneroid sensor is integral with the MAF. On older models it was not & used to get full of dust & cease to operate properly. Cleaning generally fixed it.
Old Nov 30, 2011 | 05:58 PM
Super Moderator
Sorry the poster in post #2 above is wrong!
The aneroid/barometric pressure sensor is separate to the MAF on the M271 & thus is suspect. Clean or replace sensor 80 in the diagram. As you can see it's been updated a few times.
80 A 004 153 33 28 SENDER UNIT
ALTITUDE SENSOR
Replaced_By: A 005 153 72 28 001
80 A 005 153 72 28 PRESSURE SENSOR
ALTITUDE SENSOR
B18 001
PRESSURE SENSOR INTAKE PIPE
B28
B28 001
Good luck
Old Nov 30, 2011 | 11:12 PM
Just saw this... my bad. I didn't even stop to think about what engine you had... Good catch Glyn
Old Dec 1, 2011 | 01:26 AM
Super Moderator
No problem. We are all trying to help. I don't know if the newer sensors can be cleaned. Might now be sealed.
Old Dec 1, 2011 | 01:41 PM
ulmapache's Avatar
Thank you Glyn!!! This confirms what I suspected. I had the car in to a stealer for a $200 diagnostic, they found no codes, and failed to notice a disconnected vacuum line...so nothing wrong w/ car...18mpg is good....I found line after a week of beating my head against a wall.... I have one on order, should be here today, around $40. Here's something to check out, the sensor crossreferences w/ Chrysler(Mopar) MAP sensor for Crossfires. Is it possible that the Mopar sensor has the same parameters? Might come in handy if no MB parts supply available locally, and you don't want to do the internet thing. And thanks to all who have helped me in this long journey!!! Will post a big thank you when I see MPG come up to specs.....
Old Dec 1, 2011 | 02:04 PM
Super Moderator
It is possible. The Crossfire is built on a Benz Chassis.
Old Dec 7, 2011 | 03:28 PM
ulmapache's Avatar
Ok folks, fixed p2228 code, some more came up, am giving it a break for a couple of months, one code indicates a short to ground in MAP circuit..... I swear I'm going to donate this thing to a heavy weapons shoot in Bald Knob KY.....so long as I get the first shot with the biggest gun.... Again, thanks for all the help, I'll get to the bottom of this eventually.....
