More transmission problems
Old Nov 27, 2011 | 02:42 PM
arthur8804's Avatar
mercedes c230 Kompressor
I replaced my radiator because the transmission line was leaking. Before this the transmission was acting wierd and not wanting to shift and other issues. I though this was because the fluid was low. I just replaced the fluid and got it to the right level at 80C. The transmission is still giving me the same problems though. It does not want to shift out of first gear and it jumping when I go from park to drive. I hate to say this beacuse I am scared of the answer, but the radiator that was in there was the dreaded Valeo radiator. Anyone able to tell me some good news?
Old Nov 27, 2011 | 03:22 PM
contact148's Avatar
2003 c240 4matic wagon
did you FLUSH the tranny??
if you just changed the fluid/filter thats only 4L or so i used 12L when i did my flush i kept going till the fluid was red (it started out black)
i used this thread
https://mbworld.org/forums/c-class-w...n-related.html
Old Nov 27, 2011 | 04:10 PM
Glyn M Ruck's Avatar
Super Moderator
Please tell me you kept a sample of the old fluid to check for glycol. If the clutches are damaged by coolant you have a rebuild ahead of you.
Also check the electrohydraulic bush on the front RHS diagonal of the transmission for oil leaks. If the O Rings leak this will cause all sorts of misbehavior. This is where the TCU plugs into the transmission. The TCU is mounted under the front kick plate in the passenger footwell. Worse case is oil wicks up the harness & into the TCU. Please check this.
Please get hold of an OBDII scanner & read codes the car is storing.
Old Nov 28, 2011 | 10:45 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
A 2005 Benz should not have the transmission contamination. The problem started after you hit something in the road.. perhaps you should make an insurance claim?
Old Nov 28, 2011 | 11:08 AM
Super Moderator
How do you know it's a 2005?
Old Nov 28, 2011 | 11:12 AM
LILBENZ230's Avatar
His previous thread. https://mbworld.org/forums/c-class-w...-problems.html
Old Nov 28, 2011 | 11:27 AM
Super Moderator
You are too clever squire Matt!
Old Nov 28, 2011 | 11:36 AM
arthur8804's Avatar
I did not drop the pan. Could this be a problem caused by too much transmission fluid? I want to drop the pan and replace the fluid but I want to read the codes first. I can not afford to spend money on something that will not fix it. I'm already into it about 400-500
Old Nov 28, 2011 | 08:50 PM
contact148's Avatar
yes too much or too ,little can cause trouble
BUT you need to read the codes 1st
then drop the pan change the fluid and filter
many auto parts places will read your codes for free
call around
Old Nov 28, 2011 | 09:07 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
why did u replace the radiator if u only needed to replace the trans cooler line?
Old Nov 28, 2011 | 09:14 PM
arthur8804's Avatar
It was the fitting in the radiator that needed to be replaced. They do not sell this part indivisually, so that whole radiator needed to be ordered.
