C230 Sport Coup's All things AT Transmission related
Rating: Thread Rating: 10 votes, 5.00 average.
Old Mar 31, 2008 | 06:46 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
C230 Sport Coup's All things MBZ 722.6 AT Transmission related
So, just flushed my tranny last weekend.
And got the report back from Blackstone Labs.
For those of you just joining this discussion
(thats spread all over the forums on several different platforms)
Start reading here.
The automatic tranny is one of the most expensive items to repair on the vehicle, and for people like me, a complete mystery as far as anything DIY.
But you can improve your shifting, and hopefully extend the life of the tranny by flushing on a regular basis.
I paid the dealer in Sac to do a flush, but the invoice showed only 4 quarts were used. For the record, on late model cars with the 5 speed auto tranny, nearly 9 quarts are needed (consult your owners manual) and as Mercedes saw fit to delete the drain plug from the torque converter, and proper flush requires 13 quarts according to the instructions on the service DVD. I used 12.
The service DVD is available for $60 from 1-800-FOR-MERCEDES.
Well worth it!
Attached is the report from Blackstone on my tranny oil.
It seems to imply that Sac MBZ did not do the flush they claimed to do.
But I can't prove it, though I did check it after they did it and it was green at that time, which according to the report indicates oxidation.
Luckily for me, NO WATER!!!! Wooo Hooo!
Water is a common issue with faulty radiators.
So, I will in the near future be posting the slightly different process I used to do a complete flush which involves removing the hose at the radiator that goes to the transmission fluid cooler.
All in all I'm running much smoother shifting, and the adaptive stuff is still adapting.
More to come!
File Type: pdf
Old Mar 31, 2008 | 07:02 PM
More links for informed reading.
The original http://www.mercedesshop.com/Wikka/Trans7226Fluid
But states there's a drain plug for the converter that doesn exist in our cars, and isn't a complete flush.
http://www.benzworld.org/forums/w210...b-service.html
And lastlly pdfs from the service DVD with the suggested method of flushing the tranny and converter.
https://mbworld.org/forums/attachmen...3&d=1203651872
https://mbworld.org/forums/attachmen...4&d=1203651872
And lastly, soon my pics and documents detailing the one man version.
Available NOW.
The 2 quarts of gear oil were for the diff, but never got to it.
Verify Part Number with a free electronic parts catalog from mercedes
https://epc.startekinfo.com/epc/coverage.jsp
Order parts online from a dealer at a discount-
Search on "trademotion" and "mercedes".
I'm using Autobahn in Norcal these days.
Old Mar 31, 2008 | 07:39 PM
rubensans's Avatar
Brabus K3
Old Mar 31, 2008 | 08:13 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Start reading here.
Well worth it!
More to come!
Okay, read your DIY, nice work, and great ideas. Some notes on the cooling line connection to the radiator. That little bugger is yes, hard to get out, but harder still to insure that you have fitted it in correctly. So, after you run it, inspect that fitting a number of times to insure you have NO LEAKS.
On my pan, I couldn't remove the 5 mm hex fitting. She just wouldn't come down. I loosed the bolts holding the pan to the tranny, and then loosened one side to tilt the pan. This allowed a good amount of fluid to come down. Then I dropped the pan with what was left of the tranny fluid.
Last point, don't forget to thoroughly clean the pan magnet. This little number will catch the metal bits that go loose from the gears. Heck when I do my next flush, I might even get another one.
Cheap and really good insurance on removing the metal shavings that the gears put off.
E
Old Mar 31, 2008 | 08:34 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Good stuff, Todd! Thanks for posting this. I'm going to add this to the AFTERMARKET/DIY sticky.
Old Mar 31, 2008 | 08:43 PM
Well there was too much good info mixed with bad, and it was getting hard to keep it all together. Splinter had the idea of draining at the rad instead of getting a shower from underneath the car, which might be fine on a lift, but really sux if you're on your back.
It's not an easy task getting that bugger off the rad, but it went back on in a flash. And watching the black guk drain every so quickly into my plastic bottles, well, it was strangely and oddly satisfying...a car guy thing ya know.
Just knowing it''s clean makes me feel better about driving the car.
Shifting was getting a little dicey. Now it's nothing but sweetness.
Also his C32 had a different pn for the oring, and he suggested 3/8"
hose, which was was too small.
I had to use the gas stove to soften it, and the end of a ratchet to
ream it out. Which is why I'm suggesting 1/2".
It would seem odd that his intake to the rad might be smaller.
The basic problem with tranny flushes is that you'll never know if it was actually done. Doing it yourself is a royal PIA, but you will know it was done right, no cut corner, no cut rate parts or fluids.
As stated in the report they're stating it's not been flushed though I paid to have it done. Who knows. 4 out of 9 quarts is still a lot of crud.
So much for the "lifetime fill".
"The greenish tint you mentioned is what an oil looks like after is starts to oxidize heavily. You can see this at the insolubles as well. These are solids in the oil and not only show the oil has been run too long,they also show the filter was no longer doing a good job. Wear metals were high and some of these are likely factory leftovers since this appears to be factory oil. They may not show a major problem, but they have a long way to go before we can call them normal (see universal averages based on a ~37,000 mile oil run). Check back in 10,000 miles.
It was a lot of work, not an easy job, but next time would be easier.
I wrote this as much for myself as you guys so I can remember. he he
Half the problem was just getting all the right stuff together.
Use some eye protection when you're under the car.
Old Mar 31, 2008 | 08:51 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Great job, C230 Sport Coup! Fresh ATF FTW.
Old Mar 31, 2008 | 09:11 PM
E
I think I put like a 22mm socket over the 5 mm hex, put on my safety glasses and PULLED! When it popped loose it spun around about 5 times with the hex still in it.
And yeh, definately check for leaks all around, and clean the pan, including the metal shavings in the magnet.
Also just an FYI here's the link to the WIS service sheet for the W203
Note one of the 1st things listed is changing the fluid every 60K Kilometers!
(Well it specifies certain VIN ranges or whatnot, but still....)
https://mbworld.org/forums/attachmen...3&d=1187681971
Old Mar 31, 2008 | 09:14 PM
Mu9enx's Avatar
01' C32o
did you go to the sacramento dealer in arden/howe?
Old Mar 31, 2008 | 09:16 PM
Yes, but overall it seemed like they did a good job.
Lots of free stuff under warranty I hadn't even asked for.
It could just be that 4 quarts out of 9 just doesn't cut it.
Old Mar 31, 2008 | 09:18 PM
Mu9enx's Avatar
01' C32o
oh i see, that's where i enabled my xenon-present setting for free; at first he even wanted to charge me 50$ to plug it in!
thanks for the helpful PDF, i'll be sure to try it out!
Old Apr 1, 2008 | 09:16 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Great write-up and information
Damn, that fluid coming out was NASTY Analysis reflects that, as well as debunking MB's claim to lifetime fill on the transmission.
Hoping someone figures out a DIY on the 7G. If not, I may have to dig into it at some point and figure out how to fill it without a dipstick tube.
Old Apr 3, 2008 | 02:11 AM
No dipstick tube?
Old Apr 3, 2008 | 03:14 AM
shizo's Avatar
2002 C230 Coupe
Awesome DIY!! This is next on my list of fun things to do. Thanks for the info!!!
Old Apr 3, 2008 | 05:04 AM
Not fun. If I could afford to pay the dealer the 400 + they'd charge, I would...but I'd never know if they did it....like I already had it done once
(but that was 40K miles ago) At least I know it was done right.
Old Apr 3, 2008 | 11:09 AM
johnand's Avatar
Super Moderator
No dipstick tube?
Nope, there is no dipstick tube on the 7G transmission. It is totally sealed and is filled from the plug in the bottom of the pan with a special machine.
Old Apr 3, 2008 | 11:51 AM
Well, be sure to have it flushed ~ 40K miles, at least the 1st time.
Sounds like it'll be expensive.
Old Apr 4, 2008 | 02:22 AM
datgai's Avatar
'02 C230K Coupe
I had bad luck at Sacramento. I kept taking it in for an oil leak and they said it was "normal", when they replaced my roof they soaked my shade in oil, the hatch glass was replaced but they didn't put in the panels right and I could see all the pads on the glass. Again this was "Normal". :shakes head:
So then I started going to El Dorado. Found engine was leaking in 3 places as well as other stuff and kept my car for a couple weeks. Last time I changed my oil I noticed my pan was leaking (again) but right under a few of the bolts...THEY STRIPPED 2 of my oil pan bolts!
Sorry to hijack your thread a bit. Anyways, thanks for the rightup! I'll definitely be doing it again soon since I had MBSAC do it. How long did it take you?
Old Apr 4, 2008 | 03:41 PM
Hmmm....
I went in for oil change and tranny flush at 85K miles, and told them to look for anything they could find, since I was getting close the end of the warranty. They put in a whole bunch of parts, but one of the things I wanted fixed was the IR sensor on the doors.
They only did the drivers side, I guess since after 2002 they were only on the drivers side?
I ended up going to Smyth and making them do it on the passenger side, had to show them it was on the covered list in the warranty, as they seemed clueless as to what was actually covered.
But the list of stuff they replaced in Sac, well I was pretty amazed, but they also hit me for $100 goodwill payment for stuff I didn't specifically ask for, and it appears perhaps the tranny flush wasn't done?
I'll never really know.
Which is why I did it myself this time!
Old Apr 4, 2008 | 06:17 PM
datgai's Avatar
'02 C230K Coupe
They seem really hit or miss in Sac. I couldn't get them to do my last FSS under warranty because the computer said it didn't need it until 52K.
Oh well, I try to do all my own maintenance or hire on of technicians who work in the office depending on the project (only pulley so far)
Old Apr 7, 2008 | 02:58 AM
772.9 Transmission Oil and filter change
Johnand I found what you wanted...
on the service DVD.
Everyone should buy one.
1-800-FOR-MERCEDES
60 bucks.
Old Apr 7, 2008 | 04:45 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Automatic transmission- oil and filter change,
transmission 722.6
validity restricted, vehicles as of VIN end no.
A745749, F648300, R173714
Okay, can someone please explain what this means in layman's terms? For example, is that A745749 ONWARDS, or all cars BEFORE that one?
Old Apr 7, 2008 | 05:18 AM
transmission 722.6
Don't over analyze.
How many miles you got?
Did you see the color of the stuff that came out of my car?
Yuk.
The newer service sheets show this as a maint. item.
Old Apr 7, 2008 | 10:02 AM
johnand's Avatar
Super Moderator
on the service DVD.
1-800-FOR-MERCEDES
60 bucks.
Thank you. I am calling today for a service DVD.
Looks fairly straight forward, just need to see if I can procure the filling adapters for a reasonable price. The only thing I see as a potential problem, is getting the fluid temp via Star Diagnose. I would imagine using a Fluke infrared thermometer should get me close enough.
Old Apr 7, 2008 | 01:27 PM
On yours, it appears you can't really overfill, as it has like this overflow tube in the pan.
I noted a few other parts that had updates, software, and different size tubes that supercedes certain cars...
You'll need some sort of pump to get it into the pan...
you could alway use one of those drill powered pumps,
like the Sureflow on boatersworld for 20 bucks, which I use to do oil changes.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
