No park light left front after replacing some bulbs
I have Xenon lights on my -01 W203. The inner bulbs and park bulbs were so yellow, so tonight I bought two new H7 4700K bulbs and two LEDs with electronics to fool the can-bus and make the lights look more like the Xenons.
Ok, first I replaced the H7s. Quick job. So far so good. Then I replaced the front right park bulb with the LED version and tested it. Nice bright and white light. Worked a treat! Then I went for the left side park bulb. Took out the old one (which was in working condition, but kinda yellow). Put in the new. Turned on the lights. No light. Malfunction warning in the display. Wiggeled the bulb a bit. Got a light. Put the cover back on, and sat down in the drivers seat ready for a test drive. Started the car. Got a new error message about "left front park". Checked it again. No light. Took it out. Put back the old one. Still no light. Thought: "Must have blown a fuse". Checked the fuse panel overview which said: "Parking lights - Electronics", instead of a fuse number. S**t!
With the new LED now in place, the error message actually disappeared again, but I still have no light. What the heck have I done?
How to resolve this?
Moral of the story: "If it works, don't fix it."
Bugster
(Please excuse my english. Not my native language.)
If you installed the LED backwards, it would not light. If you left the resistor installed and replaced the incandescent lamp, it would probably not light because you are drawing more than 5 watts when you add the resistor and lamp consumption together. It might also throw the error message.
Double check the LED and see if the polarity is marked. The (+) should be connected to the wire that is NOT brown. The wire color is different for left and right side.
Good Luck!
Good Luck!
Any more advices? Disconnect battery and hope for a ECU reset?
Went back to the stock bulbs. Problem solved.
Guess there is something fishy about those expensive LEDs I bought.
Stockers are yellow and ugly. But at least they work.
Moonlight Blue #80 is closest.
HOW DID YOU CHANGE THE PARKING LAMPS!!??!? I seriously can not get my hand in there to rotate and remove the lamp.
I have a 2005 C230 with OEM Bi-Xenon and an intermediate front left parking lamp...so I went to change both today - and I just can not reach...
Tips, thoughts, ideas...my wife joked she will try as her hand is 1/2 the size!
Thanks!
Jake
So today i took the car out during lunch time at work and as the weather was a bit cloudy, i noticed 3 errors on the instrument cluster.
- Left Parking Light
- Left Low Beam
- Left High Beam
What i've noticed:
- Everything on the right side was working flawlessly
- Everything on the left side was dead
- Left Parking Light would switch on periodically
- Left Low Beam dead
- High Beam dead
- When switched to Left Parking Light (only), if the Left Parking Light bulb would not light up, the left fog would. If the Left Parking Light bulb did light up, then fog light would not. I guess the system would automatically bypass the Left Parking Light in case the bulb is dead and switch on the fog light. Point to be noted.
- Left Parking Light would light up when i wiggled the wire a bit. Looked like some loose connection.
- Removed the big plug and put it back
- Now everything is back to normal
- Still have the 3 errors on the instrument cluster though. I figure they would probably go if i disconnect the battery and re connect it again.
Took the car out during lunch time today as well. On my way back, the weather was partly cloudy and the 3 errors appeared again. I then noticed that my Right Low Beam was on while driving even though the switch was in the 0 position. I tried every position on the knob but nothing would change.
Switched off the engine, everything was out.
Started the car again and switched on the headlights but only the right side worked.
Any ideas how to fix this?
A simple job of swapping the stock 5W bulbs to 5W leds turned into a nightmare. I should never have replaced the stock bulbs with 5W leds.
Hope this may help.
WHat do you call 'large plug" ?
where is it located ?
Thks, I have similar problem, left side parking light no longer works, even if replaced by tested original led component, and left fog light takes over§.
Thks for the help,
Michel
