Help with Engine Problems
Old Dec 6, 2011 | 08:34 AM
stansfield's Avatar
2003 c-240 with 43K miles, regular maintenance no problems.
Yesterday, the check engine light came on - I drove for abou 30 miles 40 minutes - I thought the gas cap was to blame.
I parked fo 8 hours and drove home ~40 minutes 20 miles - no check engine light, no problem.
Today - started it up and check engine light on - can't move it out of park - I checked the engine and oil in the bottom of the pan.
How bad do you think this is?
Any help would be apprecited.
Old Dec 6, 2011 | 08:42 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Not following you on the "checked the engine and oil in the bottom of the pan"...
Old Dec 6, 2011 | 08:47 AM
stansfield's Avatar
Engine Problems - Help
Old Dec 6, 2011 | 08:50 AM
Yidney's Avatar
2008 CLK550 Cab
I assume you are taking comfort in the fact that your engine still has oil. The fact that your check engine light came on likely has nothing to do with whether you have oil, nor does the fact you cannot shift it. Do you literally mean you cannot move the shifter out of park?
Old Dec 6, 2011 | 09:45 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
You need to get a code reader and post codes. We can't help you without them, as it could be many different things.
Old Dec 6, 2011 | 11:04 AM
RobertG's Avatar
things with and without wheels
If you can have the codes read at AutoZone for free, that will help out in finding the cause of the check engine light.
If the shifter will not come out of park position it could be a bad brake pedal switch.
Old Dec 6, 2011 | 11:15 AM
phister's Avatar
06 C230 SS 6spd
Yup get that cel read
Old Dec 6, 2011 | 08:06 PM
Glyn M Ruck's Avatar
Super Moderator
Moved from W209 forum & merged.
