m272 engine
Old Jan 2, 2012 | 06:41 AM
Remis's Avatar
w203 C280 2007
m272 engine
Hello
I have auto mercedes w203 C280
Vin WDBRF54H57A952983
Issue: 1-ohm to blackouts in silindre.
Candles have changed, the new has not prašlo.
This morning the diagnosis made and issued error code:
0630 P0300,
0634 P0301
0060 P0015.
Master of the rolls, then replaced the space measured pressure in silindre (show 6 bar) no result.
blackouts when.
the master advised that must be opened to make engine gilizy, change some seals and balans shaft, etc. (I would bypass costly almost 2500-3000 $) to Stati did not know exactly what's the problem.
thoughtless open motor without knowing the exact problem I'm
volnujet.
Can you help me with this problem?
Zahrani thanks.
Dajti tips.
Old Jan 2, 2012 | 12:12 PM
harrison1277's Avatar
Kompressor Sport Sedan 05 M271
Originally Posted by Remis
Hello
0630 P0300,
0634 P0301
0060 P0015.
blackouts when.
volnujet.
Zahrani thanks.
Dajti tips.
hmmm.... what
Old Jan 2, 2012 | 12:26 PM
Remis's Avatar
w203 C280 2007
Originally Posted by harrison1277
hmmm.... what
Hi,
Please error codes m272 engine.
Old Jan 2, 2012 | 03:14 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Hi,
Remis, Try this site. You may find them.
http://www.obd-codes.com/trouble_codes/
Old Jan 2, 2012 | 04:13 PM
Carsy's Avatar
Hi,
Old Jan 2, 2012 | 04:25 PM
Remis's Avatar
w203 C280 2007
thank you
Old Jan 3, 2012 | 02:27 AM
Glyn M Ruck's Avatar
Super Moderator
You have a misfire on Cylinder 1 - check coil & plug.
You have a camshaft timing issue. Might be magnet - might be balancer shaft sprocket.
Read this thread.
https://mbworld.org/forums/c-class-w...-bank-1-a.html
Old Jan 12, 2012 | 04:44 PM
Remis's Avatar
w203 C280 2007
Hello,please help read this error m272 engine
0632 Р0300
0636 Р0301
0060 Р0015
0160 Р2135
0161 Р0123
0166 Р0222
2066 Р0118
1909 Р0108
0271 Р0011
Old Jan 12, 2012 | 04:51 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
0632 Р0300
0636 Р0301
0060 Р0015
0160 Р2135
0161 Р0123
0166 Р0222
2066 Р0118
1909 Р0108
0271 Р0011
P0300 - Random Misfire
P0301 - Misfire cylinder one (both codes make sense)
P0015 - Timing over retarded Bank 1 (this is the camshaft sensor problem)
P2135 - Throttle position sensor
P0123 - Throttle position sensor (possibly related to 2135)
P0222 - Throttle position sensor (related to 0123)
P0118 - Engine coolant temp circuit high
P0108 - ???
Old Jan 12, 2012 | 05:34 PM
Super Moderator
PO108 = Manifold Absolute Pressure/Barometric Pressure Circuit High Input
PO011 = "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P2135 = Throttle/Pedal Position Sensor/Switch "A" / "B" Voltage Correlation
Old Jan 12, 2012 | 05:53 PM
Super Moderator
It is only the balancer shaft sprocket problem if you get PO16 & PO17 together.
Old Feb 24, 2019 | 04:35 AM
timthemechanic's Avatar
2006 ML350
m272 misfires and one cam sensor codes
I came to the same conclusion because when I pulled the covers and aligned the crank at 40 the cam marks lined up perfect. tested the magnet solenoids and they all pop up with power applied, figure the p0017 cam sensor is causing misfire codes.
