Squeaking in the rear suspension
C230 K Coupe (05)
Hi guys! First of, Happy New Years! ![Wootrock](https://mbworld.org/forums/images/smilies/wootrock.gif)
Secondly, I have crazy squeaking noise coming from my rear suspension!![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I believe (after greasing the bushings on the endlinks and sway bar and after speaking with a trusted mechanic) it is the teflon coated ball joint on the adjustable camber arms I have. It seems like I have to get the ball joint replaced and that this squeaking will occur every time the teflon coating gets used up (once a year). Any other options besides replacing the ball joints every year? Not sure if there is a teflon spray or an equivalent that will do the same trick as a teflon coating.
TIA!
G
BTW, great resource for anyone else having issues with their suspension: Common suspension noise solutions
TIA!
G
