transmission
Read this thread for info & cobble up a syringe to top up.
The fluid & filter must be changed every 39K miles
https://mbworld.org/forums/c-class-w...nsmission.html
This is the conductor plate.
did you always have a harsh transmission shifting issue esp going from 1-2-3 gear? Because i brought it to MB about twice already and paid 200 total in dianostic fees to find out it was nothing "tranmission reset" which didnt fix the problem. So if thats my problem and its 1000 dollars I might bring that up to them instead of just getting my fluid changed.. bc they are going to do the fluid change anyway with that part change
As for your year model, on another thread, it is said that it comes in one whole piece and the part itself cost close to $1000.
the mechanic said it did throw a code but i can't remember the code. no my transmission was running fine up until that day. but later that day it was running fine. the mechanic said it will happen again but that he would reset it for now. i am going to get it fixed when the part comes in. they have had a lot issues with this.we will let you know the code thurs. or fri. when we take it to get it fixed.
It's strange. The conductor plate was the cause of trouble in early iterations of the 722.6.
You would think by now that whoever supplies this $150 piece of plastic with basic circuit connections on it could manufacture these things reliably.
Problem is MB stopped selling the valve bodies!!!!!!!!!!! They are only available through MB dealers if the proper logs and paperwork are complete and the dealer does the work. You CANNOT buy just the valve body at a dealer, distributor, or online outlet anymore. So, even your indy mechanic that has a proper STAR system to SCN code it CANNOT get a valve body to replace yours. As far as I know, there are laws against this. Since they are failing at such a high rate, and are only available at the dealer, the price is almost $3000 for the unit alone. I had searched parts.com months ago when mine started acting up and I could get one for ~$1200 shipped.
Here is an indy posting about the issue: http://jayauto.wordpress.com/2011/06...-transmission/
I'm sure Mercedes reasoning is that the dealers are the only qualified people to replace this. However, we all know how incompetent MBUSA dealers are - do they even know the 2007 has a 7G transmission?
I'm concerned at the link you posted from that mechanic who says these are "failing so often". Are we getting ready to see a wave of hugely expensive 7G failures as the cars get older?
Mercedes stance on not supplying the valve bodies is part of their anti-theft policy
I can see this on EIS, smart keys, etc, but the transmission valve body
Guess it's more bad news.
