Need New Engine - Possible Upgrade?
Compression test showed 0 compression in cylinders 2 and 3 and about 40 lbs. in 1 and 4. After some digging, it looks like the timing chain malfunctioned, which threw the cam timing off and caused the piston to smash into the valve. I will say that there was limited testing done (plugs, fuel pressure, etc.) done in an effort to save money.
So, here's the meat of the question: I need a new engine and the guy is currently searching salvage yards, but has anyone ever done a conversion from the M271 to the V8 from a C55?
Off the top of my head, the relevant issues would be motor mounts, position relative to the transmission (and even whether the stock tranny could handle the V8), and ECU. Given that they're already tearing the car apart, if this a reasonably feasible idea and, if so, what other issues do you guys think I should look into?
This literally happened overnight, no CEL or any signs prior to the event. Any other ideas or suggestions are definitely welcome.
so you might be good, you will need an ecu and all that good internal stuff.
check out the w209 forum, one of our members switched out the 320 engine for the c32 engine. i believe 203 member psheck did the same.
look for those threads as it will let you know what parts you might need to swap
I heard back from the shop and it was the timing belt tensioners that failed and caused all the subsequent problems. The head is at the machine shop to replace the intake and exhaust valves in all four cylinders, so hopefully that's done soon.
While everything is pulled, we're going to replace the timing chain, tensioners, gaskets, plugs, and thermostat (unrelated, but there was also a code for that). Anything else we should be paying attention to while we're in there?
As for other things, off the top of my head, I'd say motor mounts and give the tranny a good going over. And do a wire tuck and custom valve cover, too.
Good luck with all of the repairs!
I imagine this is costing quite a bit?
I was parked on a pretty steep hill and didn't have much gas, so at first I thought it might be a fuel pump issue. I turned the car off, put it in neutral, and let it drift to the bottom to even things out. No change.
He's still putting together the estimate to include all the ancillary parts, but he's thinking close to $4k at this point. The shop was recommended by quite a few people and all his work (parts and labor) come with a 12 month warranty, so I'm at least hopefully that it'll be fixed properly.
2. might as well get a new car instead of doing a engine swap. Waveykat (C320->32) got his done with an awesome deal that normal people don't have access to.
And yes, he replaced the whole front end with the C55 front end.
And someone else did fit a C43 engine into a W203.
That was a nice car. Had like 8 piston brakes and sheet.
In that case, he didn't replace the front end.
Wavey Cat put a C32 motor in?
I though Peter (Pshek) was the only guy who got that done.
Brabus has a stroked (over bored?) 5.8L m113 in standard w203 - it fits and after talking w/ the xf guys who have been doing m112->m113 swaps, the m113 only need roughly 4 more inches of space to work and that space is available between the front of the NA m112 to the back of the radiator/fan (ive measured :x). The xf guys have been using smaller C43 fans in front of the radiator to make extra space for the V8. Personally, if a m113 fits into a standard w203, I bet an NA m273 would also fit :x ~390 hp + 7spd trans? Yes plz!
ps -Wavey has a m112k from an slk32 in his car with matching transmission. His deal was unbelievable (that *******).
To the OP.. $4000 to repair a $6000 car?
Engine swaps to greater power require a diff change.
Someone did put a S55 (V8 kompressor) into a c320.
http://www.youtube.com/watch?v=xBJQ_...Q285e4dxzgJyce
http://www.youtube.com/watch?v=qRjm2...20HQjKSTg6kz86
My Swap: https://mbworld.org/forums/c-class-w...stions-25.html
Page 25 i think :-) enjoy
Make sure that she is enhanced properly.
