bank1 or bank 2
Subscribe
Feb 10, 2012 | 11:44 PM
2007 c230, which side of the motor is bank2?
Reply 0
Feb 11, 2012 | 01:03 AM
Quote: 2007 c230, which side of the motor is bank2?
Driver side.
Reply 0
Feb 11, 2012 | 08:06 AM
By OBDII convention Bank1 always contains cylinder 1.
Reply 0
Feb 11, 2012 | 10:57 AM
great thanks guys, now that i narrowed it down to the d/s, which cam sensor is the exhaust?
i see 2 per bank, I presume one is intake and one is exhaust, the faults im getting indicate the "bank 2 exhaust cam sensor" is bad
any diagrams avail to ID the exhaust sensor?
i did search
Reply 0
Feb 11, 2012 | 12:00 PM
Quote: great thanks guys, now that i narrowed it down to the d/s, which cam sensor is the exhaust?
i did search
Hope this helps.
Reply 0
Feb 11, 2012 | 12:55 PM
Quote: Hope this helps.
just what i needed....thx
Reply 0
Feb 14, 2012 | 02:25 PM
i did search
It is likely not a cam sensor issue. What is the DTC # you got? It is likely the notorious M272 cam position magnet issue. Check out this thread: https://mbworld.org/forums/c-class-w...-bank-1-a.html
Reply 0
Feb 14, 2012 | 03:12 PM
Quote: It is likely not a cam sensor issue. What is the DTC # you got? It is likely the notorious M272 cam position magnet issue. Check out this thread: https://mbworld.org/forums/c-class-w...-bank-1-a.html
mine is p0025 code times 2
exhaust camshaft position timing - over retarded (bank 2)
i can clear it and it returns on the 2nd key cycle
Reply 0
Explore
Feb 14, 2012 | 04:01 PM
That is one of the codes for the magnet issue. Change the offending magnet and not the sensor to fix it.
Reply 0
Feb 14, 2012 | 06:49 PM
+1^ listen to John!
Reply 0
Feb 15, 2012 | 09:21 AM
1 more + ===> listen to John!
Reply 0
Feb 15, 2012 | 10:14 AM
1 more listen to john
Reply 0
Feb 17, 2012 | 12:35 PM
i am dont worry already ordered the magnet.....they were so cheap i went ahead and ordered 2 of them just in case...........
thanks guys
Reply 0
Subscribe
Currently Active Users (1)
