? about wheel alignment
i would go ahead and get the 4 wheel alignment done their gunna check your entire susupension anyways so ull find out if anything else is damaged
cause if your caster or camber or toe is off that 1 tire is going to wear down abnormally causing your car to pull
make sure u get a print out of the specs so they dont jack u around
