My C is hurting
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Like the title says, my C sedan is hurting. The cars just randomly shot me with multiple problems all in one day after not having a single major issue ever since I have owned this car. So here they are, help would be appreciated:
1) When I start my car it starts really harshly, like I will start it and It just seems like it doesn't want to turn on, it just shakes roughly and has a long start time, not a majorly long start time, but a few seconds more then normal, It is something that seems like it is going to get worst, its barely turning on. This worries me, is there any sort of maintenance or anything that I could have missed that might be causing this? Im close to 70K right now.
2) I got new wheels last week and they rubbed at first on dips and fast turns, but after shaving my inner fender it went away. I started to notice now though that when I am going slow it makes a thump sound every time the wheel does a full rotation, I even had my friend drive the car at 2 MPH while I got out of the car and listened to it, I just cant figure out were its coming from because my wheel is completely clearing the fender and spring. Is it possible that the hub could be damaged? Would this be something relevant to having hub rings and spacers? I have all correct sizes though. I am planning on having this checked out tomorrow because it really worries me
3) When i turn my front wheel its the plastic inner fender, I read that I can just heat run that to fix the problem. Would it damage the tire if I do it while the wheels are still on the car or should I take them off?
4) I literally cant hear any station on my after market deck, do any of you have this issue?
5)My LED city light bulb went out the day I got it, Ordered new ones already so that problems pretty much fixed already, but on average how long do LED lights last most of you?
sorry about all the questions, and thanks in advance!
Sorry for the patch of trouble you're having! Also sorry I can't help you with the worst of your problems, but I might have some ideas about a couple of them:
3. if the heat technique involved a heat gun, that wouldn't damage the tire. I wouldn't use a torch or anything like that around my tires.
5. LEDs should last A LONG TIME. That's one of the reasons they are so promising. Was there a box of electronics (transformer or something) that came with your lights? If so, I would suspect it before the LEDs themselves.
Good luck with the rest of the stuff on the list.
STOP RUNNING THE ENGINE!
You could have a timing chain issue, I would not personally attempt to run the car again until it was looked at. Otherwise you risk a hugely expensive repair that will make your EIS problem look like chump change. RMEuropean has the timing chain for a cheap $52 and the tensioner for $77. For peace of mind you may want to have this replaced. A lot of times the cars will make cold start noises, but you won't hear it if you don't have your door open. The rough idle is something Jordan noticed just before he needed to rebuild his M271.
The rest of the problems come along with modding which is why I don't do it. I can't help you there.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
What antenna RU using on your deck? Rear window? Have you had a tint recently?
06 C230 SS 6spd
Turning noise might be a bushing or end link. I'd jack the car up, take the wheel of and have some one turn it from lock to lock. I had a thumping issue after awhile and it turned out the end links on the sway bar want tight enough. Tightened it down now no more noise. And while you got it up you can heat fender liner. Antenna might be a tint issue if you just got it tinted. Also did you get the antenna amplifier adapter? Schoche has one
The adapter that I got for my coupe looked like that but the one in the sedan is shorter
I drive a Toyota Hybrid...
u can't really avoid inner fender running if u run on stock shocks, it happened to me and it really drives me nuts back then when i slam my coupe on 19inch wheels on lowering spring, coilover fix the problem ![wwf](https://mbworld.org/forums/images/smilies/chairshot.gif)
You can scan the car with an OBDII reader and it will show if codes are pending. Pending codes don't show lights.. a key will not cause the issue.
It really could be several things. Maybe it has a sticky throttle body or something like that. But if it makes any sort of weird rattle noises at cold start when it does this, you're playing Russian Roulette with it.
Hey Peydidy, if you need an OBDII reader, I have one you can borrow. Really sorry to hear about these problems, you have such a nice car. GL with getting it all good again. Btw, does this mean you are driving your coupe for now? And how does it feel with the CO's?
Ya I am clearing fine in the front Iv checked, I can fit a quarter in between the caliber and wheel easily so I don't think thats the problem
Yikes![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Do you know were I can get the reader? and thanks for all the info, after seeing how serious it could be I stopped driving the car and have been driving the coupe until I get the problems fixed.
Yikes
2004 C240 4Matic
I bought this one at the recommendation in posts from Glyn and its great, and inexpensive.
http://www.harborfreight.com/can-obd...enu-98568.html
Good luck.
Good luck.
Good luck.
Good luck.
http://www.autozone.com/autozone/acc...er=603853_0_0_
My local auto zone has it in stock so that way I don't have to wait for it to ship from harborfreight
Hi, sorry dude, if it's a 1.8 kompressor, I concur with the other gentlemen, I am finishing putting mine together after my timing chain stretched enough to be out of the tensioners range, skipping a few teeth on the intake cam , bending 4 intake valves, it also happenned out of nowhere , i would just unscrew the valve cover and look at how loose the chain is, if you can move it at all , you need a new one. It's not hard to change at all I think, let me know how it turns out, cheers.
Actually technically AutoZones, Kragen/O'Reillys, etc. aren't supposed to do that for you now. State of California, in their infinite need to control every single aspect of our lives, has decided that it is unfair to mechanics if people can find out what is wrong with their cars for free and passed a law banning auto parts stores from lending OBDII's. But usually if you are nice and know a bit about working on cars you can convince one of the employees to lend you their personal ones. At least that is what I did until I bought my own.
I don't live in Cali, but in my area the part's stores can lend you the store's reader with your license in on trade, but they cant come check it for you like they used to (was always annoyed by that anyway!)
