Oil in harness- Which harness is it?
https://mbworld.org/forums/c-class-w...light=Ichibans
The only issue i have at the moment is erratic idle on startup. I'm not sure if the oil in the harness is the cause of this? My current fuel consumption is 7.5lt/100kms.
You'll notice from the link Glynn posted that the alcohol bath doesn't have much oil in it after soaking the harness. That's cause small braided wire can only hold so much oil, and its a minuscule amount compared to what you'll flush out of the O2 sensor sending units. Thus why I don't believe its worthwhile to replace the harness, especially since only half the harness is affected. You'd be better off revisiting the cleaning a few times down the road as the last of the oil works its way out of the harness. This is why I'd recommend not replacing the O2 sensors at first. Clean everything and monitor gas mileage. If it doesn't improve then replace the O2 sensors and hope most of the oil has worked its way out the bottom.
Good luck, let us know how you make out.
Will attempt this next week as i have plans for the comng weekend.
Dealing with this issue thru MB Canada as we speak... So far it has been frustrating and I am in the "never want to buy a benz again" mentality... Never had such issues dealing with BMW.... apparently a 7 year old Mercedes this is to be expected...funny my BMW was 15 years old with almost 300K Km and was trouble free.
A service campaign was issued in the US... but not recognized in other markets..
FILE:
SERVICE: GROUP 00 OF SERVICE INFORMATION BINDER
PARTS: GROUP I OF INFORMATION _ PARTS & ACCESSORIES BINDER
Campaign No. 2009100001, December 2009
TO: ALL MERCEDES-BENZ CENTERS
SUBJECT:
Models 170/203, Model Years 2001 - 2004 / 2002 - 2004
Replace the Camshaft Adjustment Solenoid(s) and Install Adapter Harness(es)
Revision Date Purposea 12/15/09 Inclusion of reimbursement information- 12/04/09 Initial issue
This Service Campaign has been initiated because Daimler AG (DAG), the manufacturer of Mercedes-Benz vehicles, has determined that due to the settling properties of the seal of the camshaft adjustment solenoid specification, oil may enter the engine wiring harness (es) through the electrical connection of the camshaft adjustment solenoid from capillary action. Dealers will replace the camshaft adjustment solenoid(s) and install an additional adapter connector harness (es) at the next workshop visit.
Prior to performing this Service Campaign:
^Please check VMI to determine if the vehicle is involved in the Campaign and if it has been previously repaired.
^Please review the entire Service Campaign bulletin and follow the repair procedure exactly as described.
Please note that Recall and Service Campaigns do not expire and may also be performed on a vehicle with a vehicle status indicator.
Approximately 66,113 vehicles are affected.
To date mercedes has offered up to pay for 50% of the parts ($2000) while I'm on the hook for 50% parts plus labor ($4300).... It's going in for a second opinion to another dealer... I figure if the ECU, MAF sensor, O2 sensors X2, wiring harness X2 (one at $578) etc.etc.etc... were all shot the car would not run...and it does.
Yes i did manage to sort out the oil in harness problem. Going with what the guys on the forum had suggested, i had the harness removed and cleaned.
I used a aerosol spray (electronic contact cleaner i think it was called). It was cleaned 6 times just to make sure all the oil was out of the harness
I also had the upstream and downstream 02 sensors replaced along with the MAF. The total cost of the parts was about R6,200.
Did you replace your cam magnet?
It is suggested that I do (Cam magnets R819.60), they also recommended that i change the harnesses (R684.78). My vehicle ran down from mpumalanga to Durban (700km) giving me 6.8l/100km and coming back again 7.1l/100km. vehicle have no misfires no problems what so ever. Engine light came on yesterday had it diagnosed, drove 45km back home, light off, havent came on since.
Wondering if i shouldnt just replace the magnets and the harness and just clean all the other sensors. and hope that nothing else needs to be replaced.
Is the price of the wiring harness R684.78?? I was quoted +- R6,000 from mercedes.
If the price of the harness is indeed R684 you should replace it.
Does you Merc have the M111 engine? and is it a kompressor?
I have a 2003 180Compressor m271 engine, i dont know if the oil reached the ecu yet, but assuming that my car doesnt have any stutters or any irregularities i dont think so, im taking my vehicle to a ex merc technician on Monday for a in depth check up (R450) and then will start ordering the required spares, then will take a day or two before they pitch up. Hopefully have it running on Thursday.
Depending what other hidden costs is im gonna try and replace, but when the wallet starts getting empty, i'll try and repair where ever i can. My technician also recommended that i replace, but also said if need be we can clean it, he also solders on the inside to stop the oil from coming through again the 2nd time around.
So now what code you have?
And did you replaced the magnets and the 2 Harness's?
I had code p0366
and changed the cam sensor from the rear driver side ,
then i had this p0340,
now p0020... o boy.
Thanks,
Thanks for the advice!, I have look and the harness has white stickers,so it looks that has not been changed!, so the recall was on the harness only? or for those round magnets too?
Now if this is a recall ,do i have to pay at the dealer?
What i am thinking all this codes is related to the oil , leaking somewhere into the wires.
Thanks.
