Weird rattling noise at 3k rpm
Old May 12, 2012 | 05:38 PM
Al93's Avatar
'04 C230K 6spd
Hi all... My car is making an obnoxious rattling noise at 2800-3000 RPM.
I have the rare 2004 C230K 6SPD, I plan on selling it soon because I don't want any expensive problems in the future...
I really need to fix this, any help is appreciated.
Here is a short video of the noise I made... Please excuse my english
Thanks in advance
Old May 12, 2012 | 05:47 PM
Al93's Avatar
'04 C230K 6spd
I checked the heat shields along the exhaust but I'm pretty sure it's from the front of the car...
Any specific parts I should check?
The last thing I want to hear is that it's a transmission problem.
Old May 13, 2012 | 01:48 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Surely that is not the timing chain slapping against the cover...
Cats rattle. Are you sure it's the front and not like front center? The video makes it very hard to tell. Does it do it under load too? Or just in neutral?
Old May 13, 2012 | 11:52 AM
Al93's Avatar
'04 C230K 6spd
It does it no matter what gear it's in...
I just noticed it does it at 1500 too. I read something saying that 1500 and 3000 rpms are the ones that usually makes the most vibrations in the car..
I would really like to fix this myself rather than taking it to a shop because it seems like an easy fix..
Old May 15, 2012 | 08:01 PM
davefennell's Avatar
w208 k 200 cab 6 speed man 2001
HELLO I HAVE A CLK 2OOK AND I HAVE A SIMILAR RATTLE BUT THAT IS THE VARIABLE VALVE TIMING CHAIN COG. I GOT ANOTHER FROM EURO MERC FOR £160 BUT HAVENT GOT ROUND TO FITTING IT YET BUT STILL DRIVES OK.MERC SEVICED IT TWICE AND DID NOT NOTICE IT? LIFT THE LID AND LISTEN. WOULD LIKE TO KNOW IF ANY BODY ELSE HAS GOT THE RATTLE GOD LUCK DF
Old May 15, 2012 | 10:13 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Al93,
Your English is fine. How many miles on your car? I agree with LILBENZ230, it is not a timing chain. It could be something that is vibrating and reaches a resonant frequency, but it seems to have more of a scraping or buzzing quality to it. The sound also seems to indicate that it is a relatively light part. I think a heavier part would make a much different sound - a much lower frequency.
If you could have a friend rev up the car while you record your video, that would help. You might also be able to eliminate the engine as a possibility by putting a long blade screwdriver on different parts of the engine and put your ear up to the handle. It will work like a stethoscope and may help you pinpoint or eliminate things that could cause the noise.
If it is a heat shield or other mounted piece. While your friend is reving the engine, you could use gloves, a piece of wood or anything to hold the suspected pieces. A piece that is causing the noise would probably stop making it when you hold on to it or press on it. It would at least sound different.
Look for something that is not real loose so it would flop around but something that is just a little loose.
Good luck and keep us informed!
Old May 17, 2012 | 10:12 AM
Al93's Avatar
'04 C230K 6spd
Problem solved. Thanks lilbenz, dave and ncmudbug!
I lifted the car and checked the whole exhaust pipe and it comes out that the part that was supposed to be welded to give support to the pipe wasn't fully welded, it was just touching the pipe... I didn't noticed it until I shook the pipe a bit. Thanks guys
Old May 17, 2012 | 10:21 AM
LILBENZ230's Avatar
Ah the infamous heat shield problem. Glad you got it fixed easily.
Old May 17, 2012 | 07:40 PM
ncmudbug's Avatar
Glad you fixed it!
