HID Fog Lights Not Working
The problem is, after the installation, the bulb wouldn't light up. It would try to ignite for a second then shuts off.
I measured the voltage with an voltmeter and it would turn on and off every few seconds. So I think it's the system's way of telling the car there's a bulb out.
So would I need to get a Load Equalizer to trick the car that a regular bulb is there? Or is there some other way to get around this?
I already have Bi-Xenons on the car, so I don't think the Xenon Present would have any effect because the fogs aren't linked to the headlights.
Any help would be appreciated.
Sorry to upset you, but are you vision-impared? Why on Earth would one already having Bi-xenons need HID foglights ??? To **** off others on the road? I have enough issues with a$$holes driving with their foglights on - front and rear, no matter what weather conditions - for no other reason than trying to "look cool". I might seriously consider installing a focused strobe light facing backwards to have something in return - enough is enough, and I do know how to do it.
I just got an 9006 HID Kit that I'm going to use for my foglights.
Where did you get your kit? How much was it?
I think it veries between dealers.
I dont get it.
Fog lamps are mounted low enough.. how the heck will they blind you???
Most euorpean drivers know how and when to use their foglights (front and rear). Why can't other drivers get a clue?
"Most" OEM foglights are directed/focused correctly using a combination of bulb size and reflector shape. Altering this in any way can cause light to scatter upwards into other driver's eyes and making the foglights useless for anything but "Hey, look at me. I think I'm cool" devices.
but foglamps are nothing compared to idiots who drive around with their highbeams on.
I have HID's in my high beams so people learn REALLY quickly to turn their high beams off when they're coming at me. :0)
hey tomguy, does installing aftermarket hid systems in you C void any warranties? i want to get some for my car but dont want to kill the warranty.
And TomGuy's headlights are stock xenons. If he aims his foglights down properly, no one should be blinded. Cheap SUVs with their high mounted headlights cause way more blinding problems than properly installed xenons on a sedan.
that's understandable i suppose.. as for my OEM fogs... i use them sometimes to help illuminate the sides (ie sidewalk).. the left foglight seems to be pointing lower to the ground.
Amen to that, pokerFACE. My dream is to find the engineer at GM who thought it would be a great idea to make the bright lights (at full power, no less!) into Daytime Running Lights. What an idiot. I wonder why GM lost so much market share in the past two decades???
Saturn has had that problem since about 1995. It has prompted the US government to mandate changes but I have yet to see them. GM's persistent lobbying to the US government to make DRL mandatory seems crazy. I understand if it becomes law in the US, they can make one car for all North American countries. The crazy part is that if they follow the lead of EU manufacturers, they can turn DRL on or off by a switch like MB, Volvo and others. Why spend the money on lobbyists?
HID present doesn't apply to the driving lights. Bummer, eh?
Plus also, I got the kit for cheap (I think). 225 dollars on ebay for the kit with the Phillips Ballast and the Phillips 9006 D2S 4100K bulbs.
....The crazy part is that if they follow the lead of EU manufacturers, they can turn DRL on or off by a switch like MB, Volvo and others.....
Actually my 2000 GM SUV had that feature. I had to press the dome light switch like 3 times and then it would turn off the DRLs until the next time I started the car.
