Oil in Coolant Tank.
Old Jun 30, 2012 | 02:56 PM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
I have 2003 C-230 coupe with 141000 miles. I discovered that I have oil in my coolant tank.
I don't know if it is engine oil or ATF. How do I know if it is ATF and it is due to Valeo Radiator issue.
I try to find if it is Valeo Radiator or Behr, but I could not find the marking or label on Radiator.
Please can some one tell me where I need to look for label or marking for Valeo or Behr Radiator. Is marking on top of Radiator or bottom or driver side or passenger side.
Old Jun 30, 2012 | 09:05 PM
Glyn M Ruck's Avatar
Super Moderator
See splinter's thread in DIY stickies on radiator identification.
Thats not good!. If you are sure no one poured oil into the wrong place:
Get a test kit to check for combustion by-products in the coolant. This will tell you if you have a blown head gasket.
Take a sample of transmission fluid & have it checked for glycol.
Good luck!
Old Jul 1, 2012 | 12:43 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Any bluish-white smoke coming out the exhaust pipe,..... if so, blown head gasket.
Wipe your oily finger on white paper,.... transmission oil usually have a bit of a reddish tint to it,... ok, not the most scientific method.
Old Jul 1, 2012 | 09:34 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Our tranny oil looks more like yellow green after it's been in a while.
Old Jul 1, 2012 | 11:19 PM
When I did my partial transmission change at 60K km (39K miles), my old ATF came out dark brown-black with a bit of reddish tint (noticeable with looking at the edge or shallow drops). See photo,..... hmmm,... am I the only one with a craving for pig blood soup (its and Asian thing!)
New ATF (Fuch Titan 4134) was clear reddish colour.
Old Jul 2, 2012 | 12:40 PM
Jkw's Avatar
Jkw
2004.5 C 230
That sounds Bad,
Good luck
Old Jul 2, 2012 | 01:10 PM
Super Moderator
In ROW outside NA the Genuine fluid is not dyed red & is a greenish/straw colour.
C230 Sport C is right - sometimes the red fluid ends up looking like this.
