Check Engine light for Cam Position vents 1&2 on C230?
Old Jul 3, 2012 | 07:04 PM
06ezC230's Avatar
2006 C230 Sport
Check Engine light for Cam Position vents 1&2 is what the independent mechanic told me, as to why the check engine light popped on for today, anyone else have this problem? It randomly turns off then pops back on again
Also had my oil changed by them and the multifunction keeps saying "check engine at next gas station". I checked the dip stick and it's just fine. Again, anyone else having this problem as well?
Kinda disappointing cause I just bought this 06 C230 with 61k
The car is running just fine. Seems slow but I came from a Subaru STI, most C230's not have much pick up?
Old Jul 3, 2012 | 08:45 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
On mobile, so try a search for p0012 under my username for you solution. It is the cam magnets.
Old Jul 3, 2012 | 08:59 PM
06ezC230's Avatar
2006 C230 Sport
Awesome thank you very much!
Old Jul 3, 2012 | 11:10 PM
06ezC230's Avatar
2006 C230 Sport
Which cam magnet or solenoid is which since they're four? For example, facing the driver with the driver side on the right and passenger on the left. The ones on the driver side look like a pain in the **** to get out.....
Old Jul 4, 2012 | 02:00 AM
phister's Avatar
06 C230 SS 6spd
You should just go ahead and replace all 4. Its a manufacture recall so might a well do them all, its only like 20 bucks per magnet.
Old Jul 4, 2012 | 02:01 AM
phister's Avatar
06 C230 SS 6spd
John has a thread on how its setup and how to do the change.
Old Jul 4, 2012 | 02:17 AM
phister's Avatar
06 C230 SS 6spd
C230 aren't power cars lol its good for handling but for power you should've gone for the c350 or c32
Old Jul 4, 2012 | 10:22 AM
06ezC230's Avatar
2006 C230 Sport
Just ordered all four so hopefully this will fix the fault. No problem on the slower car, just wanted to make sure it was the same across the board being my first MB and coming from an STI
