C240 2002 Please help urgent...
i have a c240 2002 car , lately i started to have problems with my transmission.
1- if i am climbing and the car try to downshift i can feel a little jerk in the car.
2- in downhill when the transmition try to upshift the car just bounce forward.
i have checked for computer errors , none
i checked the transmission oil nothing wrong and clean to
what could it be , i am frustrated please help.
When last was the transmission oil & filter changed?
Is the fluid level correct?
Check the electrohydraulic pilot bush for fluid leaks. Front RHS diagonal of the transmission.
Lift the passenger side carpet & kick plate inside the car & check the harness & floor for fluid that might have wicked up the harness.
The 2002 TCU can't be reflashed so we can't do that.
Good luck!
Pilot bush replacement.
http://www.installuniversity.com/mb/...ans_oring.html
and it does not always jerks or kick .
but i will check the passenger side carpet . and i will reply .
if you have other idea just let me know .
thx
Of course there are many possible mechanical issues with conductor plate, valve body, clutch packs, speed sensors & valve solenoids but all will throw codes. You can only read these codes on Star or with an OBDII scanner capable of reading transmission codes.
