Need help please!
Old Jul 25, 2012 | 07:39 PM
jster611's Avatar
w203
Need help please!
Hi, I just replaced the coolant on a 02 c240 with the coolant from the dealer. After replacing the coolant the motor starting smoking a little. I turned the heat full blast and notice the heater only works on full blast on 80. Any other setting the heat doesn't work and I get cool air. The smoke seemed to stop, but the motor is very hot. But the car temperature gauge is around 85-90. Can anyone help me why the heat only works full blast, i would really appreciate it thank you so much.- jster
Old Jul 25, 2012 | 09:45 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
I don't have any specific knowledge about this but the first thing I thought of was if you "burped" the system...
Old Jul 25, 2012 | 10:44 PM
jster611's Avatar
w203
yes i did thanks for the reply
Old Jul 26, 2012 | 04:36 PM
jster611's Avatar
w203
But maybe i didn't bleed the radiator properly. Can you please provide me with a guide on how to bleed it properly. Is there a pressure release valve? Thank you very much. -jster
Old Jul 26, 2012 | 06:46 PM
Glyn M Ruck's Avatar
Super Moderator
You must have air in the system if the auxilliary coolant pump can't prime which is why the heater won't work.
There is a coolant drain on the bottom of the block #71 but you need to get air out at the top of the engine.
Old Jul 26, 2012 | 07:44 PM
jster611's Avatar
w203
Not to be a pain but how do you suggest I go about getting air out at the top of the engine? Is there a way that this can be done without draining the coolant, I just put 2 gallons of Mercedes coolant in yesterday i drained it from the bottom of the radiator plug, the red plug. Thank you very much.- jster
Old Jul 26, 2012 | 09:05 PM
Super Moderator
Multiple burping & starts without allowing to overheat should do it.
Old Jul 26, 2012 | 09:32 PM
jster611's Avatar
w203
thanks
