2004 c230 - OBD Port not working.
I received the 3 snapshot devices in the mail (I have 2 other cars). The devices worked (lights up) when installed in the other two cars (not Mercedes).
However, the OBD port in my 2004 C230 sedan seems to not be receiving any power ... device LED does not light up.
On a related note can someone tell me where the fuse box is located near the steering wheel ... I looked and could not find any fuse box near the steering wheel. Perhaps the fuse to the circuit that provides power to the OBD port is blown?
any and all help is appreciated !
I'm not sure what the problem is, honestly - will a code reader work on the port?
Apparently it is a rebranded Davis Automotive "CarChip" as stated from the link below.
http://hackaday.com/2008/06/28/progr...rate-hackable/
...and can be purchased here
http://www.davisnet.com/drive/produc...p_products.asp
So I was reading about it and I saw a link for exclusions (car that it won't work on)
http://www.davisnet.com/drive/produc...lusionsPro.pdf
IIRC the correct protocol for MB is not listed in the PDF which would explain why it would not work.
Did you try taking the car to somewhere like Autozone and try their generic OBDII scanner to see if it works? Those scanners are designed to work with all OBDII protocols.
Anyway...as for the OBD port not working, chances are it's just a fuse.
Chronology of events ...
- Went to AutoZone and the very helpful technician hooked up a diagnostic meter to the OBD-II port ... no signal. He determined the socket had no power.
- Came home and opened the fuse panel (drivers side dashboard). Inside was a fuse map. It matches the fuse map posted here ...
http://www.benzworld.org/forums/w203...e-diagram.html
- Fuse 62 is designated as "Diagnostic Socket".
- Fuse 62 is also shared by Brake Lights. But Brake Lights work fine. And it is shared by tons of other stuff like ESC, ABS etc. etc. It all works fine.
- I did not bother to check the fuse since all the other stuff that depend on that fuse ... were fully functional.
- Called MB dealership and explained the situation. They asked to bring it in but they would charge a diagnostic fee of $85.00. I said fine.
- Took the car into the dealership today .. waited for an hour. The technician returned with the news that the problem was resolved ... Fuse number 61 was broken. I was confused but not make a fuss and paid the $85.00 fee.
- Confirmed that the OBD port works (Snapshot device is lit up fine).
- Came home and looked at the fuse map. Fuse 61 is for Transmission. Had I been made aware that Fuse 61 is also responsible for the Diagnostic port ... I would have fixed the issue myself.
- Called Mercedes Benz USA to complain that I did due diligence and abided by what was shown in the fuse map and should therefore be reimbursed.
- They will research and call back.
