Finally Did It!!!
Old Jul 21, 2003 | 03:29 PM
rrj's Avatar
rrj
GLK 350
Thumbs up Finally Did It!!!
After reading through this forum and looking at all the cars I finally made some mods to my car. Got a great deal from the boys at Brabus in Newport so I had them drop it. Could not afford their rims so I went with the next best thing...replicas. Got the Expression grill since I personally can't stand the "other" grill. Finally, put on the MB flat badge and here are the results...
Old Jul 21, 2003 | 03:30 PM
rrj's Avatar
rrj
GLK 350
Another pic...
Old Jul 21, 2003 | 03:31 PM
rrj's Avatar
rrj
GLK 350
Last one...
Old Jul 21, 2003 | 03:32 PM
.elijah.'s Avatar
W203
Looks great!
Looks really clean!
So you are still using the stock shocks? What did they say about keeping them? How much for the Expression grill? Did they put it on or did you do it yourself?
Old Jul 21, 2003 | 03:38 PM
rrj's Avatar
rrj
GLK 350
Thanks elijah,
Yes they are the stock shocks/struts. They said the wear on the shocks/struts depends on my driving but that they will wear faster than normal because of the shorter spring. I put on the grill myself, cost about $600.
Old Jul 21, 2003 | 03:47 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Did they not lower the front and rear the same? The gaps between tire and fender look the same for front and rear. If the car was lowered evenly, the rear should have a tucked-in look.
Old Jul 21, 2003 | 04:04 PM
rrj's Avatar
rrj
GLK 350
Jim,
That is one of the main reasons I went with the Brabus springs. I noticed that cars with H&R or Eibach lower evenly (big gap front, small gap rear). Most of the cars I have seen with Brabus springs lower more in the front, which is what I wanted (same size gaps). My car came stock with a #3 pad in the rear, which the Brabus tech said is what they use whenever they set up W203s regardless so I stuck with it. Could have gone with a higher or lower pad but I was happy with the results.
Old Jul 21, 2003 | 04:50 PM
jo17jC230's Avatar
2008 C300 Sport
Nice and clean... what kinda wheels are those? movens?
Old Jul 21, 2003 | 04:55 PM
nukblazi's Avatar
Your front is the same drop as the others from the looks of it... the #3 pad in the rear levels it out. The "springs" them selves still lower about the same.
Looks really good. Congrads!
Old Jul 21, 2003 | 05:20 PM
rrj's Avatar
rrj
GLK 350
The rims are Monet, I think they are the same as Moven. Not sure. As for the springs, I stand corrected. I beleive Brabus springs do not lower as much in "the back" as others do. I know a couple of people which have the H&R springs and even with the biggest pad (#4) their gaps still remain uneven.
Old Jul 21, 2003 | 05:38 PM
TNblkc230wz's Avatar
C320 Coupe
I like the double spoke rims!
Old Jul 21, 2003 | 06:17 PM
rrf's Avatar
rrf
Please post your drop measurements.
The correct way to measure is:
From the center of the wheel straight UP to the arch above the tire. This will verify the amout of drop in question.
Thanks!
Old Jul 21, 2003 | 06:41 PM
LorinserCClass's Avatar
The True OG Modded out W203
Thumbs up
Nice grill There is just something about that grill instead of the "ebay" grill that is so much more impressive. Nice rims too! Are they chrome?
Old Jul 21, 2003 | 08:06 PM
I would think an uneven drop would negatively affect braking & handling.
Old Jul 21, 2003 | 08:21 PM
brabus c's Avatar
Brabus w203
all i can say is .... i LOVE Brabus... good work
Old Jul 21, 2003 | 08:23 PM
pocholin's Avatar
Volvo V90 CC
Very nice job, looks great, love the wheels!
Old Jul 21, 2003 | 08:57 PM
nukblazi's Avatar
24 3/8ths rear
25 7/16ths front
with the number 1 pad in the rear
Old Jul 21, 2003 | 09:17 PM
Addy's Avatar
C240
rrj, very nice grill, does it same as MHDezent grill? does the shop has a web page?
Old Jul 21, 2003 | 09:27 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Jim -- if you look at any original ("European") pictures of Euro cars - no matter what make - you'll see that the front sits much lower compared to what we get in the US. As far as I know, the reason is a US regulation mandating certain clearance between the front bumper and the ground. So, essentially, Euro automakers detune suspension to meet the US regulations to be able to sell cars here. In light of this, "uneven" drop restoring equal gaps is an improvement rather than otherwise. Just look at it from a different angle - if you were an auto designer, why would you make uneven gaps in the first place?
Old Jul 21, 2003 | 09:33 PM
vadim's Avatar
rrj - nice job! It looks perfect. The only thing I would suggest - if I may - would be spacers to push the rear wheels out a little (10-15mm).
nukblazi's Avatar
Jim, the wheel wells are uneven, the rear is actually lower then the front. Meassure the bottoms of wheel well on the inside, towards the door, to the ground.
But yes, and uneven drop, could skew braking and handling, wieght transfer, high speed stability, etc... so, which is even?
Old Jul 21, 2003 | 10:33 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
You will only have the rear tucked in if u use #1 spring pads. With #4 pads it wont.
Hers the rear of my c230 with #1 pads.
Old Jul 21, 2003 | 10:37 PM
rrj's Avatar
rrj
GLK 350
Thanks!
Car is in the shop. Once I get it back will measure.
Old Jul 21, 2003 | 10:40 PM
rrj's Avatar
rrj
GLK 350
Thanks enri007. They are machine polished. I was going to go chrome but when I saw the shine on them I decided to stick with em'. Next step euro-strips and bi-xenons.
Old Jul 21, 2003 | 10:42 PM
rrj's Avatar
rrj
GLK 350
Yes it is the same. I bought it from Evosport.
