HELP!!!! Brand new cam sensor and now leaking oil but not through harness
i'll have to take it back to the shop but its 25 miles away from my home and i just feel its unsafe to drive the car with all that oil coming out.
BTW, what's your location,... if you're in USA,.. why not just have MB Stealership cam sensors, plugs, wires, etc,... for free,... under recall.
now im at 159000 miles. i decided to replace it because i saw oil leaking through the connectors.
but thanks for the tip. i did notice that the rubber peices are missing. what caused that though. im assuming they were there before my brother picked up the car, and that might of been the popping noise he heard. when they opened up the engine bay, they noticed that the air intake hose came off. i belive those rubber pieces knocked it off. but what would cause those to pop out. ?
If you're in USA,... and never had cam sensor done via MB Stealership under the recall,... then get it done under the recall,... its free. Check your paperwork.
I suspect your mechanic didn't centre the cam magnet sensor properly,... and that's why it idle rough and made weird popping sounds.
Anyways, the car was revving high, rough idle and making weird popping sounds,.... at the very least I would reposition the cam magnet sensor to make sure they're dead centre,....
No translations needed,...
http://www.youtube.com/watch?v=PoeSS...om%20benzworld
And it wouldn't be a bad idea to check the cams and timing chain,.... got to figure out where the popping sound was coming from.
