2 malfunctions
thanks
CZ
I get the periodic ESP and BAS malfunctions. They've always gone away after a reboot, that's probably what happened to you. Our cars aren't the most electrically robust unfortunately- at least mine isn't.
There is a service bulletin out for this error, it says to replace a rear axl speed sensor.
The true genius mechanic at my local dealership told me the service bulletin is wrong, that it's a short in a lead to the speed sensor. He repaired the short and told me that he would rather not replace the factory sensor if it's not truly broken.
To date, this is the only warranty service item that I've taken my C230K in for in it's 35,500 miles and 378 days. Does that make my specific car as reliable as a Lexus?
I doubt it's BAS/ESP, since one of the malfunctions was washer fluid. Are you sure the other one wasn't low fuel?
chrissy, if it's really a problem, you'll see it again. If you don't ever see it again then don't worry about it.
At least twice a day my car beeps at me for doing that and I curse back at the car. It's a viscious circle....
My guess would be that the other error would be the door is open and the key is still in the ignition.
It gives you a warning for that, but it's not listed as a malfunction. At least I don't think so.
I experienced the BAS/ESP error message after spinning my wheels in snow. There is a procedure for resetting this; I think it was: Turn steering wheel all the way left then all the way right and turn off car and wait 30 secs. Was told if this doesn't stop that error message from reoccuring then it's probably a bad sensor.
If the battery is disconnected, how can that procedure reset anything in the absence of power?
While you are in there, tell them you are getting the ESP/BAS errors too (even though you are not). They will replace that wiring harness too...
. That should add some fire to this thread -- Buell?
No, it just means you've got a "normal" M-B like the majority of us
My parents still loathe the memory of that car
