Bi-Xenon Headlamps
http://www.ebay.com/itm/USA-DEPO-01-...98b198&vxp=mtr
Are they simply plug and play as they state, meaning I remove my old units and simply install these and plug them in? What are most peple using, 6000K or 8000K?
Pete
reason i wouldnt do the bixenon on the depos is that the cuttoff isnt so great on the projectors that come in them. if you want real bixenons you can buy a set of E55 projectors for cheap on ebay and they fit perfectly in the depo housing. all you have to do is remove the depo projectors and pop in the new projectors since the mounting holes line up.
if you want to go an extra step you can get s2000, fx-r, tsx, or other projectors that offer great cutoffs and bixenon. this will still cost less than what the depo bixenon cost, they just require some diying. but theyre are DIY on how to do a retrofit.
price break down
Basic depo projector - 200 or so
Projector options - The retrofit source prices
Morimoto Bi -x mini d2s - 110
Morimoto Bi-x H1 - 120
Bi-x FX-R 3.0 - 140
Bi-x Hella Evox-R (replaces the old E55 projector) - 150
Set of DDM HID kit - 35-50
so depending on what you want it'll still be around 400 but with way better output and cuttoff than the depo bi xenon. but thats just me.
You will have to set xenon=present but it's unlikely a $tealer will do it for you since it's not MB equipment. You should look for an indy to set that for you. Other than that, they are plug and play. Check for other lights from fishcake, sometimes he has the same thing at a lower price.
Now I have right side perfect depo light in the box sitting in my garage and some hardware from the destroyed left side depo light....
goodluck...best bet is to go oem ....
Javvy
I did not need to get xenon=present and I did not have xenons before the swap. Enjoy!!!
Where in NOVA are you?
I guess I need to do some more research as it sounds like there are a ton of options available. The Xeon work very well in my C55 and look so much nicer, that is why I am looking at the upgrade for my C230.
Any insight will be helpful...
javvy
Javvy, I believe that the self-leveling feature is a sensor on the front rollbar that you wouldn't have if your car didn't initially come with the option from the factory with them. The lights would still work, but you'd have to adjust manually like you do now. Someone, please correct me if I'm way off base.
